Hola, siento no poder escribir en inglés, pero mi pregunta es . ¿Existe algún mod o plugin HIDE? Para Ocultar un mensaje y que deban estar registrados y dar las gracias para poder ver dicho mensaje?. Gracias.
Hello, I am sorry not to be able to write in English, but my question is. Does some mod exist or plugin HIDE? To conceal a message and that should be registered and thank to be able to see the above mentioned message?. Thank you. There already I have formulated my question, but there is no response. Thank you.
Thank you very much to TheSteffen and to Joshua203 for your answers. Really, I have throw what TheSteffen was indicating myself and it has worked correctly. Thank you.
The time now is Fri 09 May, 2025 16:09 • All times are UTC + 1 Hour [DST enabled]
