Post Google Does Not Index The Thumbnails Of The Images
Is there any way to tell the search engines of google that i don't index the thumbnails of the images, only the largest
menorcaSend private messageSend e-mail to user
Post Re: Google Does Not Index The Thumbnails Of The Images
For this feature you should alter BBCodes... forcing full image for bots, there is no other simple way.
Can you tell me why you would like to implement this?
Google indexes my pictures too small, if I search for on the web on behalf of a mia image is very small to the side of the other images that are larger and more visible, what I don't know how to change that code, I need a little help.
In the meantime increase the size of your thumbnails in ACP, you can raise up to 720px width with a compression level of 75/80. This will produce very small files in terms of KB, but large enough as width.
When I have some extra time I will try to suggest an edit on bbcode.php to allow bots to get the full image in posts... even if it is something I wouldn't normally activate on a website.
Ok thank you very much
Maybe robots.txt
User-agent: Googlebot-Image
Disallow: /*at*.jpg$
Disallow: /*apm*.jpg$
I am not sure this is working.
But I also can not found small images with googlesearch on menorca´s site
https://www.google.com/search?q=fot...e=lnms&tbm=isch
Steffen, if you implement that code, then images won't be indexed at all... he just wants the large images to be indexed instead of the small ones.
menorca, try this code:
OPEN bbcodes.php
$html = '<img';
            if ($user->data['is_bot'])
                $params['src'] = $img_url;
            $html = '<img';
This should show the full image url to bots... forcing them to index the full image.
Be aware that this will use much more bandwidth when BOTS index your website.
I get 3 times and that this is not in what I need to insert  And I put it that way
$params['src'] = $server_url . 'album_thumbnail.' . PHP_EXT . '?pic_id=' . $params['src'];
            $html = '<img';
Traductor Babylon
It's in the section dedicated to tag IMG.
        // IMG
        if($tag === 'img')
            if($this->is_sig && !$config['allow_all_bbcode'])
                return $error;
This code is different from that which I have said before, I apologize for my ignorance but this code that I need to modif
Are you using Icy Phoenix 2.0?
If you used icy Phoenix 2.0
