Post FAP SUPPORT - SOLVED - Problems With NuffLoad Feature! HELP!
Im getting this code when photos are being uploaded..when using the NuffLoad feature. I do have the php file. Its not missing?
  1. Warning: copy(./cgi-bin/tmp/61cec2803802c2485cc4983342499a92_actualdata0) [function.copy]: failed to open stream: No such file or directory in /home/virtuap0/public_html/forum/album_nuffload.php on line 107
  2.
  3. Warning: fopen(./cgi-bin/tmp/61cec2803802c2485cc4983342499a92_qstring) [function.fopen]: failed to open stream: No such file or directory in /home/virtuap0/public_html/forum/album_nuffload.php on line 110
  4.
  5. Warning: fwrite(): supplied argument is not a valid stream resource in /home/virtuap0/public_html/forum/album_nuffload.php on line 111
  6.
  7. Warning: fclose(): supplied argument is not a valid stream resource in /home/virtuap0/public_html/forum/album_nuffload.php on line 112
  8.
  9. Warning: unlink(./cgi-bin/tmp/61cec2803802c2485cc4983342499a92_qstring) [function.unlink]: No such file or directory in /home/virtuap0/public_html/forum/album_nuffload.php on line 207
  10.
  11. Warning: fopen(./cgi-bin/tmp/61cec2803802c2485cc4983342499a92_qstring) [function.fopen]: failed to open stream: No such file or directory in /home/virtuap0/public_html/forum/album_nuffload.php on line 208
  12.
  13. Warning: fwrite(): supplied argument is not a valid stream resource in /home/virtuap0/public_html/forum/album_nuffload.php on line 209
  14.
  15. Warning: fclose(): supplied argument is not a valid stream resource in /home/virtuap0/public_html/forum/album_nuffload.php on line 210
  16.
  17. Warning: Cannot modify header information - headers already sent by (output started at /home/virtuap0/public_html/forum/album_nuffload.php:107) in /home/virtuap0/public_html/forum/includes/page_header.php on line 1476
  18.
  19. Warning: Cannot modify header information - headers already sent by (output started at /home/virtuap0/public_html/forum/album_nuffload.php:107) in /home/virtuap0/public_html/forum/includes/page_header.php on line 1480
  20.
  21. Warning: Cannot modify header information - headers already sent by (output started at /home/virtuap0/public_html/forum/album_nuffload.php:107) in /home/virtuap0/public_html/forum/includes/page_header.php on line 1482
  22.
BulletSend private message
Post Re: Problems With NuffLoad Feature! HELP!
Did you do this part of the install file?
  1. Change "Path to cgi-in" in Admin CP to a relative path from phpBB root to your cgi-bin
  2. Create folder: cgi-bin/tmp/
  3. copy cgi-bin/nuffload.cgi to cgi-bin/nuffload.cgi
  4. CHMOD 777 cgi-bin/tmp/
  5. CHMOD 755 cgi-bin/nuffload.cgi
Also, as far as I can see, the path in the ACP should be
  1. ../cgi-bin/
and not
  1. ./cgi-bin/
lefty74Send private message
The photos upload perfect now! But why do I get the error photo
Sample photo below.
Filename: sample.JPG
Filesize: 79.01 KB
Downloaded: 800 Time(s)
I believe I solved the problem by replacing the 1.4.0 .htaccess files with the ones from the last 1.2.x version.
Alternatively, from what I gather you can just delete them too.
How would u remove that?
by using ur ftp program, you access your server folders, then delete them.
If you look at FAP 1.4.0 (or the last 1.2.x), have a look at the zip file where the htacess files are located and then delete them on the server..
I use filezilla so do not know how other ftp programs look like but on there it is rather simple.
This is what is in my htacess file under  album_mod/upload
<Limit GET POST PUT>
Order Allow,Deny
Deny from All
</Limit>
What happens if you delete that one and the others in the subfolders? Do you get thumbnails then when uploading?
http://www.icyphoenix.com/viewtopic.php?t=955
ArtieSend private message
