I have finally finished configurating my website based on Icyphoenix 1.2.0.27, and the results are pretty good. I want to thank all people who made Icyphoenix possible, it is a really nice CMS and easy to work with.
Well, my website is in spanish, but anyway here is it: http://everempire.net/
EverEmpire
Subject: Re: EverEmpire
What can I say? It looks great. I like how you kept it simple with the template choice as it made your site easy on the eyes. The organization is fantastic.
Keep it up.
- On a side note, when the next version of Icy Phoenix is released, we'll have limited to no support for previous versions. It wouldn't hurt to play around with the RC2. :)
Keep it up.
Yep
But on local fore starters. so you´re getting used to it and don´t stand in front of a big wall when Final release comes out.
A lot of thing´s are different on RC2.
And i hope that the update problems from .27 to RC2 are fixed then
Thanks :mrblue:
The first version of icyphoenix I tried was RC2, but after configuring all the forums and extra things I added some .27/RC1 mods and I ruined it all...
So I decided to start it over with .27 and to wait for the stable release to come out. Maybe I can give another try to RC2, thanks for the advice.
just play with RC2 on localserver to get the feel for it.
But wait for Final release to update your site
Generation Time: 0.0909s (PHP: 18% SQL: 82%)
