An Error Has Occurred During Installation
Subject: An Error Has Occurred During Installation
I am trying to install icyphoenix but my hosting has mariadb and not MySQL. is there any solution for my case. sorry for my bad english
My Config
xampp
Windows 64 bit
includes/pdo_class_lib.php
<?php
if (!defined('IN_ARCADE')) {die('Please use the front door');}
$db_options = array(
PDO::ATTR_EMULATE_PREPARES => false, // important! use actual prepared statements (default: emulate prepared statements)
PDO::ATTR_ERRMODE => PDO::ERRMODE_EXCEPTION, // throw exceptions on errors (default: stay silent)
PDO::ATTR_DEFAULT_FETCH_MODE => PDO::FETCH_ASSOC // fetch associative arrays (default: mixed arrays)
$database = new PDO('mysql:host='.$dbhost.';dbname='.$dbname.';charset=utf8', ''.$dbuser.'', ''.$dbpass.'', $db_options); // important! specify the character encoding in the DSN string, don't use SET NAMES
includes/config.php (Not Used)
<?php
* @package (c) 2008 - 2020 Gnu Arcade Script
* @version $Id: config.php Version.1.0
* @license http://www.fsf.org/ GNU lesser General Public Licence
$dbhost = 'localhost'; // Database host - usually localhost
$dbuser = 'root'; // Database User Name
$dbpass = ''; // Database Password
$dbname = 'arcade'; // Database Name
$dbpre = 0;
// Change the table prefix ONLY if you are using one database for everything and there's a conflict with the prefix.
$table_prefix = 'gnu_';
// DO NOT Change the table ENGINE As it's ONLY here for future changes to the Db.
$engine = 'MyISAM';
include "config_lang.php";
include "pdo_class_lib.php";
Subject: Re: An Error Has Occurred During Installation
Can you give us the error you get?
What's your MariaDB version?
https://imgur.com/gUCnPBL version mariadb is 10.2
Did you pick mysqli while installing?
What Icy Phoenix version are you on?
I think you're on recent PHP (PHP 7), which doesn't support old mysql anymore.
Recent Icy Phoenix versions support the new one, called mysqli.
I think we need to release a new version... what do you think Informpro?
Currently only GIT version is supporting latest requirements.
Informpro wrote: [View Post]
it is a clean installation
that would be fantastic
Yes, I think it's time for a PHP7-ready version :)
This would be a great notice. I'm willing to migrate my server and the new settings are PHP 7.* so lots of warnings and errors.
Also, I'm trying to implement a syntax highlighter in the new versions of IP, as I have now Geshi in my old version forum 2.0.0.86). We need syntax highlight in several languages, as a programming forum, but Geshi seems to be abandoned. Looking for a more current highlighter.
What do you thing about implementing highlight.js? Would it be better to include actual code inside IP or as a plugin instead?
Best regards,
Jesus
P.D. Forum is at h**ps://gambas-es.org (since 2009, in Spanish, BTW)
Probably would be useful, I don't remember how the current highlighting works, but it's probably not up-to-date at all.
Generation Time: 0.1111s (PHP: 29% SQL: 71%)
