I Want To Change The Terms Of Conditions, May I Use HTML In This File?
Subject: I Want To Change The Terms Of Conditions, May I Use HTML In This File?
I have some rules in my previous forum, and I'd like to add them in this forum.
But the rules are in HTML, could I use HTML in the lang_main.php file?
My question is because a while ago I changed some text in this file, just a few changes:
'Agree_under_13' => 'Estoy de acuerdo con estos términos y condiciones y tengo menos de 13 años de edad',
'Agree_over_13' => 'Estoy de acuerdo con estos términos y condiciones y tengo más de o exactamente 13 años de edad',
To:
'Agree_over_13' => 'Estoy de acuerdo con estos términos y condiciones',
And from:
// These replace the %s in the above strings
'Auth_Anonymous_Users' => '<b>Usuarios invitados</b>',
'Auth_Registered_Users' => '<b>Usuarios registrados</b>',
'Auth_Self_Users' => '<b>Usuarios específicos</b>',
'Auth_Users_granted_access' => '<b>Usuarios con permisos especiales</b>',
'Auth_Moderators' => '<b>Moderadores</b>',
'Auth_Administrators' => '<b>Administradores</b>',
To:
'Auth_Users_granted_access' => '<b>Usuarios con permisos </b>',
And inmediately my forum shows this message at the top:
4645387004
I had to reset the changes and upload again this file... Maybe I don't know how to use FTP in the correct way. Or maybe I have to change this file from ACP... I don't know :oops:
My forum:
Subject: Re: I Want To Change The Terms Of Conditions, May I Use HTML In This File?
Hi;
It seems you added a blank line before "<?php" at the beginning of the file, and that's where the error stems from.
Informpro wrote: [View Post]
Hi;
Really? I didn't write anything in the file, just in those areas...
But I have to wait because I am moving my forum of hosting...
What program did you use to edit the file?
I'll use some online program to edit HTML. I have Dreamweaver in my laptop, but it is sick :| I'm using my tablet :mryellow:
It is possible the program added a newline at the beginning of the file.
Or it is possible it saved it with a "marker" (we call it "BOM" in programming), which is invisible but still present.
if you can change encoding, you need to pick "UTF8 without BOM".
Well, I didn't understand anything that you've said :LOL: So sorry! My English is really bad, and don't understand technical words or something like that :|
Basically: Try to use a different program to edit language files.
You mean it will be better if I use different program than Dreamweaver, is it correct?
I don't know if Dreamweaver lets you edit PHP files correctly.
But do not use word / wordpad / program that have formatting. That breaks PHP.
I use Notepad++ and Dreamweaver both. It happens so rarely to me (white space) that when it does happen, it takes me by surprise.
And I agree, that is a white space add before the opening php tag or after the closing tag.
I've noticed that there are some blocks of the rules at ACP, right? Maybe I could make some changes through this area, not in the PHP files, what do you think?
I can try that too and see what happens. I have a local host server setup with like 5 IP installs on it. If I tear one up by trying something it is no big loss.
I'm adding this to my to do list today.
Generation Time: 0.0966s (PHP: 21% SQL: 79%)
