a) it is possibile to have the files of the 2.7.6pl2? I'm looking for these files to controle with win merge the mod I had made.
No, the only files witch we wtill have are for a unstable woraround 2.7.8 version witch will never work for what you try to do. This is couse we moved to new website.
You can send me by e-mail the mod or module you did and I will see if can be ported to 2.8.3 or 3.0.0 Beta 2.
The problem is that I can't remember the mod I did. I think was only for home page tpl, but ?im not sure, this is why I want to winmerge files. I'm going to look another time if I can find in the back up hard disk.
But if I don't consider mod and I installal new file of 2.7.8 and then 2.8.3 I can use database of 2.7.6pl2 to upgrade?
I think I can remade the mod, but restart with data is not so simple
b) If I upgrade to mxp 3 beta, then will be simple to upgrade to the stable version?
If you upgrade to 2.8.3 will be simple to upgrade to stable version and you will have most of modules working.
If you upgrade to Beta 2 with phpBB2 backend will be easy to upgrade to stable version, but if you plan to upgrade to phpBB3 you will probably need the script witch is converting all tables to UTF-8, dependind witch php/mysql extesions will detect phpBB. Plus there are many modules now who are not upgraded for latest Beta, but mx_smartor
FAP will work with any version of backend.
The last idea is to have phpbb3, that is more usefull for me.
