Hi there.
I would like to ask you some questions:
Is it possible to have a table at the bottom of index-page, with 2 columns. Only text. And one should be "latest 5 uploaded pics in the album" and "latest 5 comments in the photo album".
Something like they have: http://germancarzone.com/index.php
I mean with nly text, so it looks small, but yet with good information.
FAP CUSTOMIZATION - More Small Stats In The Index Page?
Subject: Re: More Small Stats In The Index Page?
I would imagine most anything is possible. Just a matter of knowing how and having the time.
Both of which I have little of at the moment.
Can you provide a bit more detail of what exactly you would want to appear in each column.
Topic moved to proper forum - FAP General Discussions And Customizations
The only way to do this is to put the info in 2 different tables .... side by side ....
but then you will run into problems with one table expanding taller ( depending on length of title, username, comments, monitor resolution, etc)
Thank you for your answer.
I have already got help creating something like this.
This is the result:
http://t-music.web.surftown.se/other/ss/phpBB2/index.php
This is the result:
hey, that looks quite neat, congrats.
would you mind sharing the code in case others would like to have something similar?
Of course. I edited mine a bit, but here is the original done by Ricky_Racer from Smartor:
For SP-1:
http://ricky-racer-55.dynu.com:333/...1.0.1a-sp-1.zip
For non SP-1:
http://ricky-racer-55.dynu.com:333/...ock_v.1.0.1.zip
lefty74 wrote: [View Post]
For SP-1:
For non SP-1:
Glad you got what you were needing.
I was having a difficult time getting the comments formated like I wanted if they contained smileys near the beginning.....
so I ended up just using the title of the pic that was commented in place of the partial comment.
Seeing as I have already done the mod, I might as well included it here.
It uses most of the code that's already in FAP, so there is not much to edit.
| full_album_pack_dual_info_block_1_0_0.zip | ||
| Description: | This MOD adds a side by side info block of recent pics uploaded and recent pics commented on your phpBB index. | ![]() Download |
| Filename: | full_album_pack_dual_info_block_1_0_0.zip | |
| Filesize: | 1.93 KB | |
| Downloaded: | 216 Time(s) | |
Generation Time: 0.1202s (PHP: 17% SQL: 83%)
