FAP SUPPORT - Exif Error
Subject: FAP SUPPORT - Exif Error
Getting this on some exif images posted to the album.
Warning: Illegal offset type in /xxxxxxx/xxxxxxx/forum/album_mod/album_exif_info.php on line 257
Subject: Re: Exif Error
kris*, check this out
http://gallery.menalto.com/node/24225
Thanks artie, I'll get my hoster to check it out.
hmm.. last post there was in 2005.
checked with my hoster, they're running php 4.4.4 on this server and have updated Zend to the newest from their registered download area which is zend 3.2.2 (i386 linux - RHE).
i still get the error.
i'll upload an image saved using this method to the icy gallery, but exif isn't enabled. perhaps you could download and test in another gallery that has it enabled though when i do.
The album post will actually accurately display the EXIF information below the photo, but this error was at the top of the page. Is there any way to just remark out the error from appearing?
Generation Time: 7.0191s (PHP: 0% SQL: 100%)
