FAP SUPPORT - Photo/Image Transfer
Subject: FAP SUPPORT - Photo/Image Transfer
I was wondering if there was any way possible to transfer
the images from a Smartor Album to the new Full Album Pack
with out having the members re-upload everything?
Any help or input is appreciated.
~Lightninghawk
Subject: Re: Photo/Image Transfer
full_album_pack_1_4_0.txt wrote:
## If you are upgrading from older versions of Smartor Album or FAP, you should first uninstall
## the modifications listed in the installation files of those mods, and then apply the ones listed here.
## There is no need to remove the SQL part, since you can use "fap_install.php" to upgrade from any version.
## Just remember that if you are upgrading from older Album version, you may need to run even the
## Personal Galleries migration step from "fap_install.php", just after having installed FAP.
Go figure it would be right in front of my face.
Thanks it's much appreciated :)
~Lightninghawk
Generation Time: 0.4825s (PHP: 4% SQL: 96%)
