I followed the instructions step by precious step while upgrading an older smartor album.
to the new FAP... But the images that were in the album previously don't show.
New photos no problem. But all that is there of the old images is the poster and the names of the image.
But when you click on it. It says image does not exist.
Any help is welcome.
Thanks in advance.
~Lightninghawk
FAP SUPPORT - Problem With Upgrade
Subject: Re: Problem With Upgrade
My guess is that you removed your original album_mod/upload folders that contained your pics and replaced with the empty (of pics) folders from the install files.
I hope you have a backup of the album_mod/upload folder.... your pics should be there.
All the pictures are there.
Thats the thing.
And other ideas?
I'm not exactly a n00b so if you
have some complicated suggestion.
Throw it at me.
Thats the thing.
And other ideas?
Throw it at me.
Is there data is the database for the images under pic_filename / pic_thumbnail
Are these personal gallery pics?
If so you need to load fap_install.php again and choose Migrate Personal Galleries.
Generation Time: 1.0382s (PHP: 3% SQL: 97%)
