FAP SUPPORT - No Full Size Pics Visible
Subject: FAP SUPPORT - No Full Size Pics Visible
I've been searching these forums for a solution and while some solutions were close, they didn't fix my problem. I have installed FAP 1.4.1 and it works great, except one thing. I can't see the full size version of any pics. Thumbnails work, albums can be created, categories, uploading pics is no problem. When I click on a thumbnail to see the pic, I get a small space with the infamous Red X. I also have issues with slideshow, but I think that is because of this same problem.
I figure this is not a fault of FAP but probably my own fault with installation or setup(first time doing anything like this). I figure this has something to do with where the pics are uploaded, again not that experienced to know exactly where to look. Any assistance to correct this would be greatly appreciated.
Site can be found at www.steps2hope.com/forum
Subject: Re: No Full Size Pics Visible
A little more testing shows that "http://steps2hope.com/forum/album_pic.php?pic_id=133&full=true" works when put into a browser directly. I'm thinking this means that FAP is doing its job and files are where they are supposed to be. I increased the memory limit for PHP to 10. Still the pics do not show up when the page is loaded. I shut down all security features in the browser to test if that was an issue, no change in problem.
Any thoughts from anyone?
I agree with you that it looks like your pics are all ok.
Besides the main image not displaying, I also see that the current thumbnail in the Navigation Block does not display either.
Do you have mid-thumbnails enabled? Does it make a difference if they are disabled/enabled ?
I really not sure what is causing your problem.... MG may have an idea.
Artie - Thanks for the reply.
Thumbnail settings have been turned on/off and multiple variations of those settings. None seem to affect the outcome.
One thought was maybe I could upgrade to the next version of phpBB. Maybe something is wrong in one of those files. Although I have reloaded both phpbb and FAP.
Dwayne wrote: [View Post]
I doubt that would be the problem here. I'll give MG a holler and see if he can take a look at this.
Subject: Re: No Full Size Pics Visible - Problem Solved
Problem Solved
"Allowed domains for hotlink" cannot be blank/empty. Once this was filled-in with the domain name of the site, everything works as advertised. Large pictures are visible, thumbnails stay visible, and even the slideshow works properly.
I didn't think about that...glad you were able to figure it out.
I think that Allowed domains for hotlink can be empty if Hotlink Prevention is set to No
I'll add an extra check in the hotlink field.
Thanks for pointing this out.
Artie wrote: [View Post]
Not sure if I tried that option combination. Hope you don't mind if I pass on breaking it again to find out. :D
Glad I could contribute at even a small level.
Thanks for a great mod!!!
Generation Time: 0.9625s (PHP: 8% SQL: 92%)
