FAP CUSTOMIZATION - Thumbnail Picture In Album.php Colomn
Subject: FAP CUSTOMIZATION - Thumbnail Picture In Album.php Colomn
How do i go about getting a thumbnail picture of recently upload picture in the albump.php column. for each category...like in between the Category column and Total Pic column.?
I've seach for the forum but i can't find any....I've look at someone site and they have it like that....but i forgot who is was..:)
THanks for your help..if you can.
Subject: Re: Thumbnail Picture In Album.php Colomn
In ACP>>Photo Album>>Configuration -- Album Index
Set Show category thumbnails in index table to Yes
Artie wrote: [View Post]
Thanks Artie. I did just that and it show the LAST PIC column but it's all blank. I do have pictures in the categories. Below is the screenshot.
ss
ss
I think you have more problems than you realize.
Your columns are all out of alignment.
The post icons appear on the first 2 categories only.
I know because those are the only two categories that have pictures upload. I can upload just fine but the only thing is..it's not showing the thumbnail picture on the LAST PIC column.
Do you think i need to recheck my modifications of the FAP? But if i change the modification wrong..it would have given me Errors but it didn't at all..
Your template file album_box.tpl has been modified badly.
Replace this file with the original
Thanks Artie...it works. However, i didn't do any modification to the album_box.tpl at all....but i went ahead and download the new FAP and replace it and it works....
Thanks again.
:wink:
Generation Time: 0.2314s (PHP: 8% SQL: 92%)
