Hi. I would definitly like for my users to be able to have catagories within their album, but I don't want them to be able to have categories inside of other categories. I think it will be too confusing for my users. ANy ideas on hwo to remove subcategories?
FAP CUSTOMIZATION - Remove SubCategories
Subject: Re: Remove SubCategories
Any ideas? I really need this feature before the launch of my website
A user personal gallery IS a category, so any category created within it is a sub-cat
Probably would not be a easy task to disable sub-subcategories from the personal galleries.
You do have the option in the ACP to disallow all sub-cat creation from the personal galleries.
[quote user="Artie" post="23159"]A user personal gallery [b]IS[/b] a category, so any category created within it [b]is a sub-cat[/b]
You do have the option in the ACP to disallow all sub-cat creation from the personal galleries.[/quote]I understand that each user actually has a category which they put their photos in. I just want my users to have a sub-category for the master category. Not another sub-sub category for the subcategory.
Any ideas?!
Any ideas?!
I understand exactly what you are asking, but it would not be so easy to accomplish.
If you just wanted each personal gallery to have only one subcat, then there is a mod here that will automatically create 1 sub cat when a user creates their personal gallery. Using this mod you should be able to set your ACP to disallow user subcat creation in PG... other than this I can't offer much help to you.
Generation Time: 0.1325s (PHP: 13% SQL: 87%)
