FAP SUPPORT - Change "Path To Cgi-in" In Admin CP
Subject: FAP SUPPORT - Change "Path To Cgi-in" In Admin CP
Hello, I was reading through the installation instructions for your gallery mod and was wondering what this means:
Change "Path to cgi-in" in Admin CP to a relative path from phpBB root to your cgi-bin
Can anyone help? :mryellow:
Subject: Re: Change "Path To Cgi-in" In Admin CP
What you have to do there is to specify the path to cgi-bin folder in your web (if it exists)
You should have it in forum root. It's included in FAP release.
You should enter ./cgi-bin/ if the folder is in your forum root directory.
Greets!
I'm not really sure what you mean :?
I am running Phpbb2 and don't have a separate website. The only web-address based box is the one that specifies where my board is. Unless you mean the gallery control panel.
If don't need Nuffload, then you can use standard upload and you don't need to apply this part. :wink:
If you really need Nuffload then we will try to help you in using it, even if that feature is not fully supported in all servers.
Is Nuffload the mass-uploader? If so, I think I'll go without for the moment. :wink:
*Edit*
It says I have some duplicate SQL directories :? I hope that doesn't matter :|
Apparently it does :cry:
I couldn't get these ones to run from the install file:
*DROP TABLE `phpbb2_album_sp_config`
+++ Error: Unknown table 'phpbb2_album_sp_config'
*# ALTER TABLE `phpbb2_album_cat` ADD `cat_parent` MEDIUMINT( 8 ) UNSIGNED DEFAULT '0' NULL AFTER `cat_approval`
+++ Error: Duplicate column name 'cat_parent'
*# ALTER TABLE `phpbb2_album_cat` ADD `cat_user_id` MEDIUMINT( 8 ) UNSIGNED DEFAULT '0' NULL AFTER `cat_parent`
+++ Error: Duplicate column name 'cat_user_id'
*ALTER TABLE `phpbb2_album_comment` ADD `comment_cat_id` int(11) NOT NULL default '0' AFTER `comment_pic_id`
+++ Error: Duplicate column name 'comment_cat_id'
That is not an issue... I guess FAP is working fine anyway... right?
Regarding mass upload, you can do it without Nuffload... so you don't need it for now... keep it disabled. :wink:
Some stuff isn't working, I got an error when I tried to delete the two pictures that come with FAP, I am assuming that clicking on any picture in the 'OTF Gallery' and 'All Pictures' will cause an error.
BTW, what is the OFT gallery?
I don't suppose anyone knows any corrective SQL?
Can you provide more details to your problem.
Corrective SQL for what ?
Generation Time: 0.1504s (PHP: 12% SQL: 88%)
