FAP SUPPORT - Mysql Database Size
Subject: FAP SUPPORT - Mysql Database Size
I am using phpBB, M2F, and Full Album Pack.
It looks like my database will reach the 100mg limit fairly soon on an active board, my database is already at 6mbs after only a week.
Is there anything I can do with FAP settings to reduce the database size?
Subject: Re: Mysql Database Size
Why you are writing 3 times the same Topic??? :?
I have delete the 2 ones before. If you want to get help you should post each question only one time :!:
Are you sure that all the space have been consumed by FAP? :shock:
Can you check album table size?
TheSteffen wrote: [View Post]
Sorry, it wasn't intentional, I know better forum etiquette than that :oops:
I don't think FAP is using more than it's share, just wondering if there were any config settings or other ideas to lower database size.
I don't know if you have some mods which charge the DB too much... but apart of that what you can do is disable and empty the search tables and integrate them using Google Search API.
I can't remember where, but I'm sure you will find some hints on how to do it @ phpBB.com.
Generation Time: 2.2981s (PHP: 1% SQL: 99%)
