Hi all.
I've just upgraded FAP to the 1.4.1 version.
I've uploaded change files and update the database.
No particulary problems, but in the album home page disappeard the otf link and the personal galleries link (also the all messages, but this is not important).
I try to change in the ACP the visualisation, but no solutions.
It is a problem only for me?
Giò
FAP SUPPORT - Upgrade Fap 1.4.0 --> 1.4.1
Subject: Re: Upgrade Fap 1.4.0 --> 1.4.1
Try to check in ACP, since now links are switchable! :mricy:
giorgioinfo wrote: [View Post]
I try to switch in the ACP, but no changes in the FAP page.
Are you sure you run fap_install.php properly?
Maybe your DB hasn't be updated.
Make also sure to have replaced all files.
I think all is done as art rule (a regola d'arte come si tradurrà :-) ).
I read in the foot of the FAP page 1.4.1, so I think is all ok.
I will check, but I'm quite sure to have done without errors.
Generation Time: 8.1584s (PHP: 0% SQL: 100%)
