Ok when trying to upload pictures into the album I cant. I fill out all the info I need, and when I click submit it bring me to a white page and nothing happens.
When I go into my cPanel and into the album folder I do see that the file is uplaoded.
Also in my admin panel I did set the file size and reolution and all that stuff. I also changed the permissions for the folders to 777 as well.
SOLVED FAP SUPPORT - Upload Problem
Subject: Re: Upload Problem
Please go to ACP -> Info -> GD Info and tell me the information it gives you (especially GD version).
Greets!
Greets!
I have the latest version of icy phoenix installed.
Version bundled (2.0.34 compatible)
Freetype Fonts Support: Yes
Freetype Link Type: with freetype
T1lib Support: No
Gif Read Support: Yes
Gif Create Support: Yes
Jpg/Jpeg Support: Yes
Png Support: Yes
WBMP Support: Yes
XBM Support: Yes
Japanese Font Support: No
T1lib Support: No
Png Support: Yes
WBMP Support: Yes
XBM Support: Yes
Generation Time: 0.0837s (PHP: 21% SQL: 79%)
