FAP CUSTOMIZATION - Changing Name Of Personal Galleries To "Members Cars&qu
Subject: FAP CUSTOMIZATION - Changing Name Of Personal Galleries To "Members Cars&qu
I would like to change the name of the Personal Galleries on the album index page to "members cars"
We are using FAP for the 356 Registry website which is a world wide Porsche club. Our whole website is being rebuilt and now is using a forum and photo gallery.
http://356registry.com/forum/album.php
Subject: Re: Changing Name Of Personal Galleries To "Members Car
in the folder /templates/mh_themes open the file album_box.tpl around line 104 there should be this code...
Where it says "{catfooter.cat_public_footer.L_USERS_PERSONAL_GALLERIES}"
Replace with desired text.
*Note: This will replace the text in the album that says "Users Personal Gallery"
Also where it says "{catfooter.cat_public_footer.L_YOUR_PERSONAL_GALLERY}"
*Note: This will replace the text in the album that says "Your Personal Gallery"
Move topic to Customization forum where it is more suited.
losthillsguy wrote: [View Post]
If you want only to change it on the album's index page then Vuki's suggestion would be the way to go.
But if you want to change it on any page that it may appear on, you should find it in your language's lang_album_main.php and modify to your need.
Thanks, I used the second option.
Generation Time: 0.15s (PHP: 11% SQL: 89%)
