Hello install FAP 141 in phpbb2 2.0.23 various mods installed, Color colorice not working. In FAP
File album_showpage.php is default the mod link file http://pastebin.com/m599295ae Can help, Greetings
MY Album http://www.kmorph.com/album.html
FAP SUPPORT - FAP 141 Color Groups Error
Subject: FAP SUPPORT - FAP 141 Color Groups Error
Subject: Re: FAP 141
Hi Morph...
What you have to do if you want to have color groups enabled in album, I think, is to define it is phpBBXS...
Open album_mod/album_constants.php
Find
Before, add
It should work now.
Greets! :mricy:
Find
Before, add
It should work now.
Greets! :mricy:
KasLimon, install code
ERROR:
Fatal error: Call to undefined function: create_date2() in /home/pcmorph/public_html/kmorph/album_mod/album_hierarchy_sql.php on line 1433
ERROR:
Generation Time: 0.1838s (PHP: 17% SQL: 83%)
