Has anyone tried to install both Joomla and Icyphoenix on the same site, and share the user registrations?
I mean.. if someone registers to Joomla portal, then it will be automatically registered also in Icyphoenix...
How can I accomplish that? Is there any script for this bridge?
Thanks!
argenta.
Joomla/IcyPhoenix Users Integration [BRIDGE]
Subject: Re: Joomla/IcyPhoenix Users Integration [BRIDGE]
well, maybe since Icy is based on phpbb2... I might try any of the phpbb2-Joomla bridge... maybe with a little snippet it might work,
eventually if I need any help, may I count on you?
buldo wrote: [View Post]
You can try, of course, but I'm not much skilled on PHP to help you. :(
Feel free to ask support here, probably someone else will help you :wink:
argenta wrote: [View Post]
Try to install the phpBB 2 one... and if you have problems we will try to help.
I was hoping there was a bridge too but no such luck????
Mareja
Phoenix az
Mareja
Phoenix az
If you read a couple posts above, you'll notice someone said there was a phpBB2 bridge. They are trying to incorporate that into their site. Hopefully they post back here letting us know the status. 8)
Hi Argenta,
Have you figured out how to install it? If yes, can you share with me?
Hi Argenta,
probably it will be easier to merge IP and Nuke 8, then IP and Joomla
since nuke comes with PHPBB 2 incorporatet
I think that the only important thing is make the users table to communicate each other.
And phpBB 2 Bridge should help in that.
What else do you need?
Or better said
Use one User Table for both
Yes, thats possible with "JFusion" http://www.jfusion.org
Before 3 month I tested it and it was working with IP 1.2.20.47 and Joomla 1.5
It was only on xampp because of freetime, but it was working. ;-)
spydie wrote: [View Post]
Generation Time: 0.6446s (PHP: 3% SQL: 97%)
