FAP SUPPORT - Problem With Apostrophe In The Comment Section
Subject: FAP SUPPORT - Problem With Apostrophe In The Comment Section
Whenever there's a apostrophe used in the comment section, I'm getting this error.
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's so vute')' at line 2
INSERT INTO phpbb_album_comment (comment_id, comment_pic_id, comment_cat_id, comment_user_id, comment_username, comment_user_ip, comment_time, comment_text) VALUES ('3019', '1159', '1', '3', 'cindee317', '437f67d5', '1232403831', 'this is great, she's adorable!')
Line : 1438
File : album_showpage.php
Can anyone help me?
I've already updated my version to the latest Mighty Gorgon Full Album Pack 1.4.1 © 2006.
Subject: Re: Problem With Apostrophe In The Comment Section
You need to add an addslashes:
http://php.net/manual/en/function.addslashes.php
This will solve it.
Generation Time: 9.267s (PHP: 0% SQL: 100%)
