Is there a mod that allows you to add a copyright note (specified in the ACP) at the top of every gallery?
If there's not, could someone help me create one?
FAP CUSTOMIZATION - Copyright Info At Top Of Galleries
Subject: Re: Copyright Info At Top Of Galleries
Same note for each category ?
Can you provide an example (edited screenshot) for the location?
ok, i'll try and get a screenshot up later today.
basically would want it in a text box/table right above the page number area at the top, on every thumbnail view page (album_cat.php, album.php, album_allpics.php). It would be about 3/4 sentances long and likely link to a larger copyright page so the ACP option would have to allow HTML.
Sorry kris*, my main PC went on the blink and I only now got it back enough to do anything.
Do you still need this?
Unsure about allowing html, but there could be a work around.
I don't think such a mod exists.
Anyway you can try to adjust Cat Description to suit your needs: I think that HTML is parsed correctly, or am I wrong?
krisbfunk wrote: [View Post]
right, forgot about the ability to use HTML in cat descriptions, that suits my needs. Thanks mighty.
Generation Time: 0.1286s (PHP: 14% SQL: 86%)
