Post FAP SUPPORT - Fatal Error: Call To Undefined Function: Checkflag() In.....
I installed Full Album Pack 1.23, later i wanted to upgrade it to 1.4.1.
Now i get the message :
Fatal error: Call to undefined function: checkflag() in mysite/album_mod/album_hierarchy_sql.php on line 81
I get this when i go to my album and in the ACP on album categorys and permissions.
The Configuration and personal album in the ACP do work
When i look what i had to change:
#-----[ OPEN ]------------------------------------------------
includes/functions.php
#-----[ FIND ]------------------------------------------------
// Mighty Gorgon - Full Album Pack - BEGIN
//--- FLAG operation functions
function setFlag($flags, $flag)
    return $flags | $flag;
function clearFlag($flags, $flag)
    return ($flags & ~$flag);
function checkFlag($flags, $flag)
    return (($flags & $flag) == $flag) ? true : false;
// Mighty Gorgon - Full Album Pack - END
#-----[ REPLACE, WITH ]----------------------------------------
// Mighty Gorgon - Full Album Pack - REMOVED
then it is not used anymore.
Wat did I forget whit the upgrade?
I uploaded all the files and changed the SQL.
Hope someone can help me with this.
MikeWSend private message
Post Re: Fatal Error: Call To Undefined Function: Checkflag() In.
I think you didn't upload all files correctly, try to delete all old PHP album files and reupload the new ones.
Ofcourse i already tried this, but somehow i seem to forgotten something.
The Album is back but i still have an problem with it.
Everything seems to work in the ACP.
The album also works, uploading works.
But i see no pictures and if i click on a thumbnail (Just the little red cross, no picture) i get this message:
Warning: filesize() [function.filesize]: Stat failed for album_mod/upload/61ca178530fa380bcbba3afec8d6ae0f.jpg (errno=2 - No such file or directory) in /home/vofpergo/public_html/JRforum/album_showpage.php on line 1213
The reason i did the upgrade was because every space in an title or description was written as
%20
That seems to be fixed now.
Can I have a link please?
Are you sure you haven't removed your pictures?
It was even after trying to upload an new picture to see if the problem with the name and discription was solved.
link to the forum is:
h**p://***.vofpergo.nl/JRforum
link to the album part is:
h**p://***.vofpergo.nl/JRforum/album.php
If I try to load the pic directly http://www.vofpergo.nl/JRforum/albu...6a089212d7c.gif I get an error...
I think the picture either doesn't exist or you have HTACCESS in those folders.
I removed the ht.access files in de album mod/upload dir.
After that, i saw that the restrictions wore false.
Because I uploaded this directory again, somehow i forget to change the restrictions again.
Now it works, thanks.
