Post FAP SUPPORT - A Few More Questions Or Problems I Can't Figure Out
I am really loving this mod but I had a few more questions. Don't know if it's because I'm a noob or if these have validity. BTW, is there a FAP Users Guide somewhere?
1. Once a pic is rated, seems user can not change rating. I remember seeing a mod awhile back that allows user to rerate, and also shows what user has currently rated the picture.
2. Is Hot or Not built in? Where is it supposed to show up? I don't see anything about it in FAP ACP.
3. Lightbox is not working at all
I'm getting "Error: Object Expected" in lower left IE warning icon
4. In slideshow, pictures still show up as true size thus stretching the page. How to resize picture on the fly when producing the output page...or better yet auto compress it when uploaded so it's permanently stored on the server as the reduced size.
5. cosmetic question:
In jumpbox, where it says
Personal Galleries
Personal Gallery Of user1
Personal Gallery Of user2
I want to get rid of "Personal Gallery Of" I finally found the only instance of this in lang_main, and i changed it but it didn't seem to reflect the change
6. Can users move pictures from personal to public and vice versa (if they own the public picture). If they don't own the public picture, can users copy pictures from public to personal?
7. Is there an Add Favorite/Bookmark picture?
I will state again, that I love FAP!!!
meaniemeSend private message
Post Re: A Few More Questions Or Problems I Can't Figure Out
There is no User's Guide for FAP....also none for phpBB that I'm aware of.
1. Can't help you, I don't know of this mod.
2. Hot or Not is disabled is FAP.
3. Hmmm...dunno ... got a link ?
4. Set pic upload dimensions in ACP
5. Now that you have changed this, create a new Personal Gallery and watch the magic
6. If unowned they can ony view, comment, rate (is permissions allow)... if owned I don't think they can move from Personal to Public
7. No
And FAP loves you to !
ArtieSend private message
1. ok when i find the rating mod i'll post the link here...i know it exists b/c i recall implementing it
2. Not sure what you mean by Hot or Not being disabled. How do I enable/use it?
3. Sorry I am testing on localhost now. But I think lightbox not working is causing same error on all pages that have thumbnail. Because all these pages have "Error: Object Expected." Which file/Where is lightbox being called? Is that protoype.lite.js?
4. I will have to keep playing with the different combinations to see how it can work.
2. Do you mean hotlinking with pictures on other site? Something like that problem I have HERE?
DarkheartSend private message
No,. "Hot or Not" is a box that pulls from your FAP that users can rate, like people Hot or Not, then cycles through the rest of the album. Some people actually started a website called www.hotornot.com, but you get the idea.
The FAP actually includes this file, album_hotornot.php, since it was part of Clown Pak, but not sure why it's not active. Hence my question.
AFAIK the HON rating system was replaced by the current rating system.
I've never used it myself, not even sure how it functions....seems to work though, by running the album_hotornot.php file
I've never used this feature... but the files are still there and should work fine (I had a go some times ago while testing ratings).
Try to use this feature and let us know if it is working.
I can confirm that it does work.  You can place the 'hot or not' link in your album index if you'd like.
Pete_ZSend private message
Thanks for the confirmation Pete_Z.
And thanks to MG for adding the Hot or Not feature to the album on this site.
I've recoded it... you'll have Hot Or Not working fine with next release.
Or you can use this...
album_hotornot.zip
Description: Album HON
Filename: album_hotornot.zip
Filesize: 2.93 KB
Downloaded: 267 Time(s)
