Just noticed one problem: the slideshow doesn't seem to work anymore (with vista). Neither on my site (www.aktuell.net, FAP 1.4.0) nor here on icyphoenix.
Anyone too got this problem??
Re: Slideshow Doens't Work
I only asked to be certain of which browser as I assume browsers other than IE 7 can be used with Vista.
I have not IE 7 on this computer, but can check/verify on another pc this weekend.
I do remember from the past that someone had an issue with FAP and IE 7.... don't remember exactly the problem....was it you ?
I just asked two friends of mine with Vista and the slideshow doesn't work on their PCs, too. So I think Visat (or the IE7) doesn't "like" the Slideshow-script. Is there a solution for this??
The time now is Fri 10 Apr, 2026 04:06 • All times are UTC + 1 Hour [DST enabled]
