Post FAP CUSTOMIZATION - No Watermark In Privat Albums?
is it possible to turn off the watermark in privat albums??
Helmut71Send private message
Post Re: No Watermark In Privat Albums?
Yes, form ACP -> Photo Album
jzSend private message
Could you tell me where to do so??
I just find an option to turn on/off watermark, to make it visible für guests / all users and to configure the position...
There is the option to use different watermark for each category, which I think is what  jz may have been referring to.....but not for the personal galleries.
You must modify code to get what you want.
OPEN album_pic.php and album_picm.php
if( ($album_config['use_watermark'] == true) && ($userdata['user_level'] != ADMIN) && ( (!$userdata['session_logged_in']) || ($album_config['wut_users'] == 1) ) )
if( ($album_config['use_watermark'] == true) && ($album_user_id == 0) && ($userdata['user_level'] != ADMIN) && ( (!$userdata['session_logged_in']) || ($album_config['wut_users'] == 1) ) )
Edited by Artie, Sun 03 Jun, 2007 18:08: Moved to FAP General Discussions And Customizations
ArtieSend private message
@artie: thank you!
What does the code do which you suggested? Does it eliminate the watermark in the personal albums colpetely or is it possible to use a different watermark, if yes where can I do so for the personal albums?
The code above eliminates the watermark for personal galleries.
There is no option to set a different watermark for the personal galleries......
What you could do is set up the watermark that you want for the personal galleries as the default and then assign (in the ACP) a different watermark for each public gallery.
@artie: thanks a lot, it is ok to eliminate the watermark.
Perhaps this could be a feature in upcoming versions, to let each user set a personal watermalr in his/her personal albums.
