FAP CUSTOMIZATION - Pagination Of Smiley Window In FAP?
Subject: FAP CUSTOMIZATION - Pagination Of Smiley Window In FAP?
So I can not believe no one has been annoyed by this tiny issue where when one clicks on the "view all smilie" pop up, has to wait for all smilies to be uploaded? I have tons of smilies, but that is becaues I have a Smiley management MOD that categorizes my smilies. FAP doesn't 'work' with this MOD... apparently FAP is using it's own smiley functions ...at least I think that is the case.
Any ideas, clues. . ?
Subject: Re: Pagination Of Smiley Window In FAP?
FAP is using a duplicated function of standard phpBB.
The function has been duplicated to avoid modifying to many phpBB core files. That's why.
I guess you may try to apply that mod to FAP as well. The code should be similar.
Yeah I tried doing that, but it's not easy thing to do. I just cant believe this doesn't bugg anyone else. Must be just me :D
Pete_Z wrote: [View Post]
Why?
The code for smileys should be really similar (I guess 99%) to the standard phpBB smiley code... what you can't find?
Try to post here, we will try to help.
Okay, according to the mod it replaces two things. one in bbcode.php and the other in functions_post.php
Complete new function generate_smilies
Below are the major edits done.
#-----[ OPEN ]-----------------------------------------------------------------
includes/bbcode.php
#-----[ FIND ]-----------------------------------------------------------------
# This is the complete smilies_pass function
// Smilies code ... would this be better tagged on to the end of bbcode.php?
// Probably so and I'll move it before B2
function smilies_pass($message)
static $orig, $repl;
if (!isset($orig))
global $db, $board_config;
$orig = $repl = array();
$sql = 'SELECT * FROM ' . SMILIES_TABLE;
if( !$result = $db->sql_query($sql) )
message_die(GENERAL_ERROR, "Couldn't obtain smilies data", "", __LINE__, __FILE__, $sql);
$smilies = $db->sql_fetchrowset($result);
if (count($smilies))
usort($smilies, 'smiley_sort');
for ($i = 0; $i < count($smilies); $i++)
$orig[] = "/(?<=.W|W.|^W)" . preg_quote($smilies[$i]['code'], "/") . "(?=.W|W.|W$)/";
$repl[] = '<img src="'. $board_config['smilies_path'] . '/' . $smilies[$i]['smile_url'] . '" alt="' . $smilies[$i]['emoticon'] . '" border="0" />';
if (count($orig))
$message = preg_replace($orig, $repl, ' ' . $message . ' ');
$message = substr($message, 1, -1);
return $message;
#-----[ REPLACE WITH ]---------------------------------------------------------
# Complete new function
//START MOD Smiley_management
// Smilies code
if (!isset($orig))
// EDIT MSTheme: smilies are in templates/..../images/smiles
global $db, $board_config, $theme, $userdata;
//Smilies for parsing: No hidden pages (hidden > ADMIN) (assumed duplicate pages),
//and get only 1 of each themed set.
$style = ($userdata['user_style']) ? $userdata['user_style'] : $board_config['default_style'];
$sql = "SELECT s.*
FROM " . SMILIES_TABLE . " s, " . SMILIES_PAGES_TABLE . " p
WHERE p.id = s.page
AND code <> '' and smile_url <> ''
AND access IN(" . USER . ', ' . MOD . ', ' . ADMIN . ")
AND (theme = 0 OR theme = $style)
ORDER BY code";
if (strpos($smilies[$i]['code'], ' ')>0) //multiple codes?
{ //Get all codes, create more records, sorting must be absolute correct
$all_code = explode(' ', $smilies[$i]['code']);
for ($k=1;$k<count($all_code);$k++)
$smilies[$i]['code'] = $all_code[$k]; //set code
$smilies[] = $smilies[$i]; //add record
$smilies[$i]['code'] = $all_code[0]; //set first code
if (count($smilies)) usort($smilies, 'smiley_sort');
$smilies_path = $board_config['smilies_path']; //"images/smiles";//###
$orig[] = "/(?<=.W|W.|^W)" . phpbb_preg_quote($smilies[$i]['code'], "/") . "(?=.W|W.|W$)/";
switch ($smilies[$i]['align'])
case 0: $align="-3px;";break;
case 1: $align="top";break;
case 2: $align="middle";break;
case 3: $align="bottom";break;
$align = 'style="vertical-align:' . $align . '"';
$repl[] = '<img src="'. $smilies_path . '/' . $smilies[$i]['smile_url']
. '" title="' . $smilies[$i]['emoticon'] . '" alt="[' . $smilies[$i]['emoticon']
. ']" border="0" ' . $align . ' />';
if (count($orig))
return $message;
//END MOD Smiley_management
and Functions_post.php
includes/functions_post.php
# Complete function generate_smilies
// Fill smiley templates (or just the variables) with smileys
// Either in a window or inline
function generate_smilies($mode, $page_id)
global $db, $board_config, $template, $lang, $images, $theme, $phpEx, $phpbb_root_path;
global $user_ip, $session_length, $starttime;
global $userdata;
$inline_columns = 4;
$inline_rows = 5;
$window_columns = 8;
if ($mode == 'window')
$userdata = session_pagestart($user_ip, $page_id);
init_userprefs($userdata);
$gen_simple_header = TRUE;
$page_title = $lang['Emoticons'];
include($phpbb_root_path . 'includes/page_header.'.$phpEx);
$template->set_filenames(array(
'smiliesbody' => 'posting_smilies.tpl')
$sql = "SELECT emoticon, code, smile_url
ORDER BY smilies_id";
if ($result = $db->sql_query($sql))
$num_smilies = 0;
$rowset = array();
while ($row = $db->sql_fetchrow($result))
if (empty($rowset[$row['smile_url']]))
$rowset[$row['smile_url']]['code'] = str_replace("'", "'", str_replace('', '\', $row['code']));
$rowset[$row['smile_url']]['emoticon'] = $row['emoticon'];
$num_smilies++;
if ($num_smilies)
$smilies_count = ($mode == 'inline') ? min(19, $num_smilies) : $num_smilies;
$smilies_split_row = ($mode == 'inline') ? $inline_columns - 1 : $window_columns - 1;
$s_colspan = 0;
$row = 0;
$col = 0;
while (list($smile_url, $data) = @each($rowset))
if (!$col)
$template->assign_block_vars('smilies_row', array());
$template->assign_block_vars('smilies_row.smilies_col', array(
'SMILEY_CODE' => $data['code'],
'SMILEY_IMG' => $board_config['smilies_path'] . '/' . $smile_url,
'SMILEY_DESC' => $data['emoticon'])
$s_colspan = max($s_colspan, $col + 1);
if ($col == $smilies_split_row)
if ($mode == 'inline' && $row == $inline_rows - 1)
break;
$col = 0;
$row++;
else
$col++;
if ($mode == 'inline' && $num_smilies > $inline_rows * $inline_columns)
$template->assign_block_vars('switch_smilies_extra', array());
$template->assign_vars(array(
'L_MORE_SMILIES' => $lang['More_emoticons'],
'U_MORE_SMILIES' => append_sid("posting.$phpEx?mode=smilies"))
'L_EMOTICONS' => $lang['Emoticons'],
'L_CLOSE_WINDOW' => $lang['Close_window'],
'S_SMILIES_COLSPAN' => $s_colspan)
$template->pparse('smiliesbody');
include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
# Complete new function generate_smilies
// Fill smiley templates for window or inline
function generate_smilies($mode, $page_id, $page_id = 0) //Called from posting.php and privmsg.php
global $userdata;
$inline_rows = 5;
//******* Get data *******//
//Initialise separate form
//Get page list for both window and inline
$access = ' access = ' . USER ;
switch ($userdata['user_level'])
case MOD: $access = ' access IN (' . USER . ',' . MOD . ')'; break;
case ADMIN: $access = ' access IN (' . USER . ',' . MOD . ',' . ADMIN . ')'; break;
$sql = "SELECT *
FROM " . SMILIES_PAGES_TABLE . "
WHERE $access
ORDER BY `default_page` DESC,title";
$result = $db->sql_query($sql);
if( !$result )
message_die(GENERAL_ERROR, "Couldn't obtain smileys page list", "", __LINE__, __FILE__, $sql);
$row = $db->sql_fetchrowset($result);
$verified = 0;
for ($i=0;$i<count($row);$i++) //Check page_id
//echo $row[$i]['title'] . "||" . $row[$i]['default_page'] , '<br />';
if ($page_id == 0)
if ($row[$i]['default_page'] ) $page_id = $row[$i]['id'];
if ($row[$i]['id'] == $page_id) $verified = 1;
// echo $page_id.'<br />';
if (($page_id == 0 || $verified == 0) && count($row) > 0) $page_id = $row[0]['id'];
$url = "posting.$phpEx?mode=smilies&page=";
for ($i=0;$i<count($row);$i++) //Build list
$page_list .= ($page_list ? ' :: ' : '');
$page_list .= '<a href="' . $url . $row[$i]['id'] . '" >' . $row[$i]['title'] . '</a>';
if ($row[$i]['id']==$page_id) $page_data = $row[$i];
$page_title = $lang['Emoticons'] . ($page_data['title'] ? ' * ' . $page_data['title'] : '');
$page_width = $page_data['width'];
$page_height = $page_data['height'];
//Get smilies
$sql = "SELECT *
WHERE code <> '' AND smile_url <> '' AND page = $page_id
ORDER BY number";
else //$mode == 'inline'
//First record is first default page
$page_width = $row[0]['width'];
$page_height = $row[0]['height'];
$sql = "SELECT s.*
WHERE p.id = s.page
AND code <> '' AND smile_url <> '' AND inline = 1
AND $access
ORDER BY number
LIMIT " . ($inline_columns * $inline_rows);
if( !$result )
message_die(GENERAL_ERROR, "Couldn't obtain smileys list", "", __LINE__, __FILE__, $sql);
//****** Fill template *******//
$smilies_colspan = ($mode == 'inline') ? $inline_columns : $page_data['column_count'];
$row = 0; $col = 0;
for ($i=0;$i<count($smilies);$i++)
$all_code = explode(' ', $smilies[$i]['code']); //Select first code only from multiple to insert
$code = str_replace("'", "'", str_replace('', '\', $all_code[0]));
$colspan = ($smilies[$i]['colspan'] ? $smilies[$i]['colspan'] : 1);
if ($col==0) $template->assign_block_vars('smilies_row', array());
'SMILEY_CODE' => $code,
'SMILEY_IMG' => $smilies_path . '/' . $smilies[$i]['smile_url'],
'SMILEY_DESC' => $smilies[$i]['emoticon'],
'SMILEY_COLSPAN' => $colspan)
$col += $colspan;
if ( $col >= $smilies_colspan) {$col = 0; $row++; }
} //Next smiley
//More smilies button * Can't check if there are more smilies than just inline, assume there are:
if ($mode == 'inline')
'S_PAGE_WIDTH' => $page_width,
'S_PAGE_HEIGHT' => $page_height,
'S_PAGE_LIST' => $page_list,
'S_SMILIES_COLSPAN' => $smilies_colspan,
'L_CLOSE_WINDOW' => $lang['Close_window'])
//Parse separate template
Yeah... so I cant figure it out... I had coded the smilies url so that I get my smilies categories showing up right, but now trying to figure out how to get the smilies to be posted on the message body because when I click on a smilie, nothing happens... so..
I did this to album_functions.php
includes/constants.php
define('SMILIES_TABLE', $table_prefix.'smilies');
#-----[ AFTER, ADD ]-----------------------------------------------------------
//MOD Smiley_management
define('SMILIES_PAGES_TABLE', $table_prefix.'smilies_pages');
Replaced this part of album_functions.php with the MOD instructions ( post above this one )
//to have smilies window popup
function generate_smilies_album($mode, $page_id) //borrowed from phpbbforums...modified to work with album
global $userdata;
// Vars needed for CH 2.1.4
global $config, $user, $censored_words, $icons, $navigation, $themes, $smilies;
$inline_rows = 5;
... etc etc etc ...
include($phpbb_root_path . 'includes/page_tail.' . $phpEx);
Still nothing.... please, if you read this, can you hint something my way..
Okay, not the kinda hint I was looking for.
How about this. What makes a smilies code get pasted onto the message box?
It is a JAVASCRIPT.
Are you using Icy Phoenix or phpBB?
Sorry for the lates reply. between work and school, its dificult to keep up with my favorite support sites! I use regular phpbb board... but you know, I will just leave it the way it is. thank you for your time!
Generation Time: 0.1365s (PHP: 16% SQL: 84%)
