Post FAP SUPPORT - Full Album Pack 1.4.1
I installed the mod and have the an error only in the admin panel.
When I click on the Photo Album Tab: Configure
I get this error
Fatal error: Cannot redeclare album_generate_config_clearcache() (previously declared in /home/content/p/h/r/phreakz1/html/forums/admin/admin_album_config_clearcache_old.php:28) in /home/content/p/h/r/phreakz1/html/forums/admin/admin_album_config_clearcache_old.php on line 28
any ideas of what it is?
grungy6669Send private message
Post Re: Full Album Pack 1.4.1
Well I think I found out what the problem is.
I tried to install the mod "Remove Frames In Admin Panel" and the error occored
I backed to the original and it is working.
Is there any way to add support to this mod?
I know it has something to do with adding the tags that null out some of the code and it nulled some of the FAP code.
Sorry, but I don't know the mod you are talking about...
What is meant for?
