KugeLSichA
 Some Help for SQL Needed
Hi everybody,
I try to port a script into my Icy Phoenix and now i need your help.
The script uses other sql statements, and this is my problem. this is the original sql statement:
- $sections_ref = dbQuery("SELECT * FROM `{$cfg['db_table_prefix']}sections` WHERE `deleted` = 0 ORDER BY `name` ASC");
- while ($sections_row = dbFetch($sections_ref))
- $seasons_ref = dbQuery("SELECT * FROM `{$cfg['db_table_prefix']}seasons` " .
- "WHERE `id_section` = {$sections_row['id']} AND `deleted` = 0 " .
- "ORDER BY `submitted` DESC");
- while ($seasons_row = dbFetch($seasons_ref))
- $main_tpl->set_var("I_ID_SEASON", $seasons_row['id']);
- $main_tpl->set_var("I_SECTION_NAME", $sections_row['name']);
- $main_tpl->set_var("I_SEASON_NAME", $seasons_row['name']);
- $main_tpl->parse("H_SEASON_DROPDOWN", "B_SEASON_DROPDOWN", true);
and this is what i have done yet
- $sql = "SELECT * FROM " . TOURNEY_SECTIONS_TABLE . "
- WHERE `deleted` = 0
- ORDER BY `name` ASC";
- $result = $db->sql_query($sql);
- $section_info = $db->sql_fetchrowset($result);
- for ($x = 0; $x < count($section_info); $x++)
- $section_id = $section_info[$x]['name'];
- $sql = "SELECT * FROM " . TOURNEY_SEASONS_TABLE . "
- ORDER BY `submitted` DESC";
- $season_info = $db->sql_fetchrowset($result);
- $season_select = '';
- $season_select .= '<form action="">';
- $season_select .= 'Select Season: <select name="season_id" size="1">';
- $season_select .= '<option value="0">-</option>';
- for ($x = 0; $x < count($season_info); $x++)
- $season_select .= '<option value="' . $season_info[$x]['id'] . '">' . $section_info[$x]['name'] . ' ' . $season_info[$x]['name'] . '</option>';
- $season_select .= '</select>';
- $season_select .= '<input type="submit" value="Go">';
- $season_select .= '</form>';
- $template->assign_vars(array(
- 'SEASON_SELECT' => $season_select,
the problem is, that my code, select all seasons, correct, but the section name is not shown by all created options.
can somebody help me with that?
#1 Thu 14 Feb, 2008 23:32 |
KasLimon
 Re: Some Help For SQL Needed
Hi, first of all, this lines are not doing anything: for ($x = 0; $x < count($section_info); $x++)
I don't understand exactly what's the error. Can you take a screenshot of the select box result?
Greets!
____________ Gabriel Anca
#2 Fri 15 Feb, 2008 13:52 |
KugeLSichA
 Re: Some Help for SQL Needed
Hi KasLimon,
thx for your help
here is a screenshot:
der red underlined word is the "section_info name" and the blue underlined is the "season_info name"
the dropdown is sorted by "season_info id" the "carom abcdef" has id "3" and the last "Test season" has id "1"
#3 Fri 15 Feb, 2008 15:32 |
KasLimon
OK I see.
One more question.
Then season_info ID and section_info ID have to be the same to make it work?
I mean:
carom id 3
abcdef id 3
carom3d id 2
neuer test id 2
test season id 1
Is this correct?
Greets?
#4 Fri 15 Feb, 2008 16:00 |
KugeLSichA
exactly
greetings
#5 Fri 15 Feb, 2008 16:02 |
KasLimon
I've been testing and I got this:
- $sql = "SELECT sec.id AS section_id, sec.name AS section_name, sea.id AS season_id, sea.name AS season_name
- FROM (" . TOURNEY_SECTIONS_TABLE . " sec, " . TOURNEY_SEASONS_TABLE . " sea)
- WHERE sec.id = sea.id
- AND sea.deleted = 0
- AND sec.deleted = 0
- ORDER BY sec.name ASC";
- if (!$result = $db->sql_query($sql))
- message_die(CRITICAL_ERROR, "Could not query season information", "", __LINE__, __FILE__, $sql);
- $season_select = '<form action="">';
- $season_select .= '<option value="' . $season_info[$x]['section_id'] . '">' . $season_info[$x]['section_name'] . ' ' . $season_info[$x]['season_name'] . '</option>';
Try it. Greets!
#6 Fri 15 Feb, 2008 16:29 |
KugeLSichA
many thanks KasLimon,
now i got it working with your help... with your code there was only showing 2 options, but it was my fault, because we checked the season table "id" but it must be the season table "id_section" (line 3)
i have it working with this code:
- WHERE sec.id = sea.id_section
- message_die(CRITICAL_ERROR, 'Could not query season information', '', __LINE__, __FILE__, $sql);
- $season_select = '<form action="tourney.' . $phpEx . '?sid=' . $userdata['session_id'] . '" method="post">';
- $season_select .= '<option value="' . $season_info[$x]['season_id'] . '">' . $season_info[$x]['section_name'] . ' ' . $season_info[$x]['season_name'] . '</option>';
- 'I_ID_SEASON' => $season['id'],
again thank you very much =)
#7 Fri 15 Feb, 2008 18:16 |
KasLimon
Nice to know it works
Greets!
#8 Fri 15 Feb, 2008 22:05 |
KugeLSichA
yes and i´m happy that you helped me with that... now i can change the other sql queries, and the whole script
if i finished it, i put it here online, maybe someone needs it... but later more infos...
anyway thanks KasLimon
#9 Sun 17 Feb, 2008 11:22 |
