Page 1 of 3
Goto page 1, 2, 3  Next
Post FAP SUPPORT - Problem Wih Mid Thumbnail
I have a serious prroblem with my mid thumbnail: all the pictures stop loading at one third (aprox.). This only happens the first time, if I load the pics a second time, it works.
What shall I do?
Helmut71Send private message
Post Re: Problem Wih Mid Thumbnail
Helmut71 wrote: [View Post]
What shall I do?
It should be a memory limit problem... try either to increase your memory limits in ACP or via PHP.INI if you can.
You may even try to reduce the size of the mid thumbs.
It's the same problem for me
FAP Limit is set to maximum 16MB and mid thumbs are now set 300px to 300 px
But I still have the same problem
TheSteffen wrote: [View Post]
Did you try to activate the OLD TUMBS GENERATION option in ACP?
Yes, but then I got only black mid thumbs
So I can better life with a half then a black one
For me it's not so importent at so moment, but if you or Artie is working on it, you can have a look at it
If you want to take a look Link
We will try to figure it out...
Yes, please have a look, cause this problem is annoying for album-viewers..
a Link to my album: http://www.aktuell.net/forum/album_cat.php?cat_id=16
I have the same problem.
KokosadunSend private message
What is strange that you are all german... do you have the same hoster?
Can you try with Icy Phoenix Beta on the same server? Just for test...
No, I'm by all-inkl.com
and Kokosadun is by Strato.
Post Re: Problem With Mid Thumbnail
I have tried Icy Phoenix.
I am overwhelmed of this board!
Great work, I`ve never seen a board like this.
The album ist functioning too.
Hm...
But what do we have for a problem with the album?
I use Categories Hierarchy 2.1.6c.
My users are very good worked in in the bord now, and I don`t want to change the system now.
What shall I do?
I have this issue when enabling the lightbox option, onmouseover the mid thumbs that generate only load a 1/3 of the way until i mouseover a second or third time.
krisbfunkSend private message
krisbfunk wrote: [View Post]
What shall I do?
Hmm..I have disabeled lightbox option...
yes, i have disabled it too, because of this. i tried turning thumbnail cache off & clearing the thumbnail cache, but still no luck.
i am for some reason unable to view mid thumbnails now, i can only get a 1/3 of the image to load on my board, running phpbb 2.0.22
can someone assist?
can someone assist?
Do you have a link please?
Can you try to reduce the mid-thumb size?
This forum is locked: you cannot post, reply or edit topics.  This topic is locked: you cannot edit posts or make replies.  Page 1 of 3
