FAP CUSTOMIZATION - [MOD] FAP Outside Pics MOD
Subject: FAP CUSTOMIZATION - [MOD] FAP Outside Pics MOD
Hello,
Update:
Topical Version: 1.0.2 - 23.3.2006
Makes it possible to add random, recent or single pictures into php files outside of the phpBB installation.
Download:
http://martin-truckenbrodt.com/down...csMOD_1.0.2.zip
Demo:
http://www.killi.org - Random Pics
http://www.killi.org/index2.php - Recent Pics
http://www.killi.org/index3.php - Single Pic
(Additional) Support:
http://www.martin-truckenbrodt.com/cgi/phpBB2/viewforum.php?f=8
Bye Martin
Subject: Re: [MOD] FAP Outside Pics MOD
Thanks Martin for reposting this mod on this site too! :wink:
Hi Martin,
I am trying (unsuccessfully) to have random pictures block for a specific user id by modifying the Random pics file.
Could you maybe help me out there?
Many thanks
Typically, I tried one more time after I posted this and now I got it to work.
If anyone would like to try it out or check for correctness
  2. ---FIND---
  3. #
  4. $sql = "SELECT pic_id, pic_title, pic_desc, pic_cat_id FROM ". ALBUM_TABLE ." ORDER BY RAND() LIMIT 1";
  5. #
  6. #
  7. --- REPLACE WITH ----
  8. # replace x with the user_id you want to display
  9.
  10. $sql = "SELECT pic_id, pic_title, pic_desc, pic_user_id, pic_cat_id FROM ". ALBUM_TABLE ." WHERE pic_user_id= 'x' ORDER BY RAND() LIMIT 1";
  11. #
  12.
This is a great add on. thank you.
I've mkportal 1.1.1 and FAP 1.4.1 ....i've tried it, but doesn't work.
Do you think is an error of mine, or that's for others portals?
I've mkportal and i've created a php block for recent pics with this code:
<?php include "phpBB2/album_mod/album_outside_recentpic.php" ?>
This is my modified album_outside_recentpic.php :
define('IN_PHPBB', true);
$phpbb_root_path = './forum/'; //set your path
$album_root_path = $phpbb_root_path . 'album_mod/';
include($phpbb_root_path . 'extension.inc');
include($phpbb_root_path . 'common.'.$phpEx);
$language = $board_config['default_lang'];
if ( !file_exists($phpbb_root_path . 'language/lang_' . $language . '/lang_album_main.'.$phpEx) )
$language = 'italian'; // set your default language
include($phpbb_root_path . 'language/lang_' . $language . '/lang_album_main.' . $phpEx);
print "<table align=center>";
print "<tr><th align='center' colspan='3'>". $lang['Recent_Pics'] ."</th></tr>";
print "<tr>";
$sql = "SELECT pic_id, pic_title, pic_desc, pic_cat_id FROM ". ALBUM_TABLE ." ORDER BY pic_id DESC";
$picspool = $db->sql_query($sql) or die ("SQL Error");
for ($i=0;$i<3;$i++) //set number of pictures for the displayed line
while ($cat['cat_view_level'] != '-1')
$row = $db->sql_fetchrow($picspool);
$sql = "SELECT * FROM ". ALBUM_CAT_TABLE ." WHERE cat_id = '". $row['pic_cat_id'] ."'";
$result = $db->sql_query($sql) or die ("SQL Error");
$cat = $db->sql_fetchrow($result);
$cat['cat_view_level'] = '0';
print "<td valign='top'><table><tr><td align='center'>" . $row['pic_title'] . "<br /></td></tr><tr><td align='center'><a href='". append_sid($phpbb_root_path ."album_showpage.". $phpEx ."?pic_id=" . $row['pic_id']) ."'><img alt='" . $row['pic_desc'] . "' src='". $phpbb_root_path ."album_thumbnail.". $phpEx ."?pic_id=" . $row['pic_id'] . "'></a></td></tr></table></td>";
print "</tr>";
print "</table>";
When I activate the block for mkportal index, I've this error:
Fatal error: Cannot redeclare class template in /web/htdocs/www.oltrelafoto.com/home/forum/includes/template.php on line 30
Well make sure phpBB2 is changed to whatever your forum is called.
OR If that does not work...
You can use HTML BLOCK and using IFRAME. That's what I use for my mxbb portal.
INSERT
Inside a file called ( for example ) recent.php
add:
<body bgcolor=#333333> ( to match your portals colour )
iframe example
<iframe src="http://www.your-site/recent.php" scrolling="no" width="100%" height="130" frameborder="0" marginheight="0" marginwidth="0" allowtransparency="true"></iframe>
You will have to make the pictures open up a new page or else when you click on image, it will stay in the IFRAME and it looks ugly... I used target="_blank" inside of album_outside_recentpic.php
Look for
add for example:
."album_showpage.". $phpEx ."?pic_id=" . $row['pic_id']) ."' target=_blank>
Ive added a nice marquee to mine... if anyone is interested. it stops the scrolling when mouse is hoverd over. works for IE and FF. =)
<marquee loop="infinite" bgcolor=#333333 behavior="SCROLL" direction="left" height="135" width="100%" scrollamount="3" scrolldelay="1" ALIGN="middle" onmouseover='this.stop()' onmouseout='this.start()' ><font color=white>
<?php include "phpbb/album_mod/album_outside_recentpic.php" ?>
</marquee>
Thank you Pete_Z,
i've only a question: in "album_outside_recentpic.php", line 28, there is
If I want only one pict, the correct input is for ($i=0;$i<2;$i++) ?
Pete_Z wrote: [View Post]
INSERT
I've created recent.php file, but i've a blank page... :cry:
I finally got the mod to work. I didn't realize the html document ouside of phpbb had to have the .php extension. Once I changed that it worked fine.
I've modified the album_outside_randompic.php file to only show one picture, and to show the picture title below the picture. My question now: How do I get the full sized image to load from phpbb instead of the thumbnail. I have poured through the album_mod files trying to figure out which variable to add instead of the album_thumbnail in the album_outside_randompic.php file.
Can someone tell me what I need to change in order to get a full sized picture instead of a thumbnail?
Here is my modified album_outside_randompic.php file code:
<?php
$language = 'english'; // set your default language
print "<tr>";
for ($i=0;$i<1;$i++) //set number of pictures for the displayed line
$row = $db->sql_fetchrow($result);
<table>
</table>
</td>";
print "</tr>";
print "</table>";
I'm trying to figure this out, but if one of you gurus can chime in with an easy fix I'd be very thankful.
Page with pictures outside phpbb - www.philmontforum.com/index.php
Thanks!
Shane
Hi Shane,
I think to change the size to mid thumbnail or full size in the code above you need to
--FIND
album_thumbnail
--REPLACE WITH
//mid thumbnail
album_picm
//or fullsize
album_pic
Thanks Lefty. Thats just what I needed! :up:
glad it worked :mrgreen:
To everyone who has got this mod to work, do you have XS (extreme styles) mod installed? I'm having troubles getting the pictures to show. The pictures will show for a split second then turn into a clickable blue rectangle. Martin said it had to do something with XS but didn't go into detail how to fix the problem.
Doesnt work for me either. Same problem, I see small rectangular box, no pic.
Here is a test page
Page 1 of 3
Generation Time: 0.0896s (PHP: 24% SQL: 76%)
