Anti Bot Question
Subject: Anti Bot Question
This mod avoids bot registrations with some kind of "dificulties"
You'll find this when registering:
registration
  • If the bot writes in the wrong box (or in more than one) it will return an error.
  • If the bot writes a wrong number/text it will return an error.
  • If the bot doesn't select the box on the left it will return an error.
A bot will not be able to read all the information and will fail. The field you have to fill is random and the field name too (in the shot you can see it's the third option, but it is randomly ordered.
Installation instructions
Anti bot question Mod Configuration
This mod is not a replacement for Visual confirmation. For more security, please activate Visual Confirmation and Accounts activation by the users.
This mod is based on VIP Code mod (the original mod asks you to enter a "VIP Code" on a field, this mod extends its function)
Greets ;)
Subject: Re: Anti Bot Question
Thanks!
Generation Time: 1.1685s (PHP: 2% SQL: 98%)
