The first MOD of this was started by TheKuKa. And he gave me the right to share my changes here.
This MOD adds bookmark links to your viewtopic so you can easily add topics to your favorites bookmark page/pages.
After a quick testing all seems to run good, but if you find any bug please report it here.
Please post also you comments here. Thanks.
## MOD Title: Bookmark Tags in Forum Icy Phoenix
## MOD Author: ThE KuKa < thekuka at phpbb-es.com > (Raul) http://www.phpbb-es.com
## MOD Author: KugeLSichA < kugelsicha at caromonline.de > (HoLLe) http://www.caromonline.de
## MOD Author:
## MOD Description: Adds Bookmark Tags in your View Topic. So you can add this topic to your bookmark pages.
## MOD Version: 1.0.1
## Installation Level: (Easy)
## Installation Time: 5 Minutes
## Files To Edit: templates/mg_themes/viewtopic_body.tpl
## Included Files: /icons_tag/ folder
## License: http://opensource.org/licenses/GPL-license.php GNU General Public License v2
## For security purposes, please check: http://www.phpbb.com/mods/
## for the latest version of this MOD. Although MODs are checked
## before being allowed in the MODs Database there is no guarantee
## that there are no security problems within the MOD. No support
## will be given for MODs not found within the MODs Database which
## can be found at http://www.phpbb.com/mods/
## Author Notes:
## You need the latest IcyPhoenix Software. It can be found at http://www.icyphoenix.com
## MOD History:
## 2007-07-30 - Version 1.0.1
## - Some code cleanup and auto generated forum url
## - ADD some new bookmark pages
## - ADD Title tag to icons
## - CHANGE the way to generate the URL, to get it working with mod_rewrite if enabled
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
## MOD Author:
## Author Notes:
## MOD History:
Demo Topic can be found HERE
Download can be found HERE
Dresden
Sabadell
BA
1 minut! xD
Tanks!
