Re: Question About Salt-forum Of PhpBB
That function is needed to improve security on forms and avoid bots and hackers to inject or run forms.
That is a good way to secure form, and I'm planning to add it to Icy Phoenix even if that would not be easy and quick as there are many forms in Icy Phoenix.
If you are porting a mod form phpBB 3 to Icy Phoenix it should be enough to remove the field from the template and the check from the PHP file. Alternatively you may implement the SALT function in Icy Phoenix and try to make it work.
If you have an example of code I may help further.
