This happens since the launch of the patch 1.2.0.27a
BUG comment in this topic:
http://www.icyphoenix.com/viewtopic...&p=26530#p26530
Greets
027-0005 Capture Images In Downloads
Subject: Re: 027-0005 Capture Images In Downloads
Aha... good job for checking this one out Kuka, that poster was being too vague to know if it was genuine (on account of hot linking), and I haven't much time for vagueness... ;)
Are you sure you did apply CHMOD correctly even to pafiledb/images/screenshots folder?
It is working fine for me.
I've checked this now and I confirm what MG says. If screenshots folder is not 777, then as one can expect... no screenshots! Otherwise it works like it always did... so not a bug after all :mryellow:
I did also notice in the pafiles files that there is a change from $images['link'] to $images['forum_link'], but this seems to work and is consistent with changes in mg_themes.cfg / rest of icy.
Yes Luca, CHMOD 777 correctly to this folder :o
I have asked private data to access and test directly on a server.
I will report back.
I will report back.
Generation Time: 0.1142s (PHP: 15% SQL: 85%)
