BUG Double Logo Using IP 1.2.21.48 RC 1
Subject: Double Logo Using IP 1.2.21.48 RC 1
When using the nav_logo block in the CMS with the new version and enabling it:
block
This is what happens with the logo:
logo
As you can see, I now have a double logo using the CMS block. Am I missing something or is this a bug? I can easily solve the issue by editing the overall_header.tpl file, but I only see that as a workaround and would prefer to use the CMS option.
Subject: Re: Double Logo Using IP 1.2.21.48 RC 1
if you want to do is remove the "dual logo" Disable block and this problem resolved. 8)
I know that I can disable the block, but the whole point of it is to move the logo into the center of the header without modifying files on the server, which is what it does on the old version with the mod installed. In other words, it works perfectly at my live site on the old version of IP, which you can see at http://www.eve-kotaki.com
because .... I began to revise and apparently can not, will have to edit by hand.
MG expects to come and a solution will, however continue to review and anything I say. ^^,
I will tag it as a bug and move it to the bug tracker.
Subject: Re: [BUG] Double Logo Using IP 1.2.21.48 RC 1
You will need to add also a top left header block with empty content.
Generation Time: 0.0854s (PHP: 20% SQL: 80%)
