It Helps With Matter Of The Forum
Subject: It Helps With Matter Of The Forum
It wanted saver to arrange a this problem what happens it is that uando I get to a forum asks me to enter my go and pass when I get to another forum he asks for the same thing me and this when marked a forum of which ahy new things I get and not ahy marked at all if someone can help me with it pls?
Subject: Re: It Helps With Matter Of The Forum
Hmmm... non capisco che cosa dice tu... Il problema in Italiano?
Subject: Respuesta: It Helps With Matter Of The Forum
My problem is in Spanish and every you see that I get to a forum he asks me login and password
because cookies are same [path]
I think
try to clear your browser cache
I think
the problem do siguio erase all the cookies and the this cache in order that I can do?
Try to use a mod called "autocookies" that will set up an [ok] configuration of them for you
And this mod wherefrom I extract it or of wherefrom the low thing?
You talk spanish so we can talk in spanish i think :mrgreen:
Descarga ese mod, subi el archivo dentro de una carpeta install y ejecutalo.
Te va a crear unos valores para tus cookies, vos solamente confirma ese paso.
Saludose
Saludose
Generation Time: 0.3077s (PHP: 10% SQL: 90%)
