Post Remove Welcome PM
hello.
please,how  I can delete this PM ??
I don't want that the private message arrives to any member.
JareckSend private message
Post Re: Remove Welcome PM
Hi
Try this on usercp_register.php
            // START - SEND PM ON REGISTER MOD - AbelaJohnB
            // According to 'netclectic' we need to set the datastamp to '9999999999' in order to
            // insure the pop-up notification about a new message existing. I concur with 'netclectic'
            // and have thus made the change to his suggestion. Thanks netclectic!
            $sql = "UPDATE " . USERS_TABLE . "
                SET user_new_privmsg = '1', user_last_privmsg = '9999999999'
                        WHERE user_id = $user_id";
            if ( !($result = $db->sql_query($sql)) )
                message_die(GENERAL_ERROR, 'Could not update users table', '', __LINE__, __FILE__, $sql);
            $register_pm_subject = $lang['register_pm_subject'];
            $register_pm = $lang['register_pm'];
            $privmsgs_date = date("U");
            $sql = "INSERT INTO " . PRIVMSGS_TABLE . " (privmsgs_type, privmsgs_subject, privmsgs_from_userid, privmsgs_to_userid, privmsgs_date, privmsgs_enable_html, privmsgs_enable_bbcode, privmsgs_enable_smilies, privmsgs_attach_sig) VALUES ('0', '" . str_replace("'", "''", addslashes(sprintf($register_pm_subject,$board_config['sitename']))) . "', '2', " . $user_id . ", " . $privmsgs_date . ", '0', '1', '1', '0')";
            if ( !$db->sql_query($sql) )
                message_die(GENERAL_ERROR, 'Could not insert private message sent info', '', __LINE__, __FILE__, $sql);
            $privmsg_sent_id = $db->sql_nextid();
            $privmsgs_text = $lang['register_pm_subject'];
            $sql = "INSERT INTO " . PRIVMSGS_TEXT_TABLE . " (privmsgs_text_id, privmsgs_text) VALUES ($privmsg_sent_id, '" . str_replace("'", "''", addslashes(sprintf($register_pm,$board_config['sitename'],$board_config['sitename']))) . "')";
                message_die(GENERAL_ERROR, 'Could not insert private message sent text', '', __LINE__, __FILE__, $sql);
            // END - SEND PM ON REGISTER MOD - AbelaJohnB
Moved to Docs... thanks Zuker, you are doing great!
THANKS!!!!
