Post How To Use Show In Portal Function
Have any of you guys run into an issue to where the "Show in portal function" on a new/existing post stopped working?
Paul_RS1Send private message
Post Re: Show In Portal Function Not Working
**Bump**
no one has any ideas??
Paul_RS1 wrote: [View Post]
**Bump**
Yes I have an idea!
I've waited months before someone noticed this feature, and now time has come!!!
Congratulation... you are the first one to have noticed this!!!
Let me explain how this feature work...
First: do not bump your post... I read every single post here... and sooner or later I'll try to help you if I can... but you have to be patient!
Now let's go on with the explanation !
Show In Portal function has been created to show some topics in portal. This feature must be used in conjunction with FORUM or FORUM_ATTACH block in portal.
If you enable one of these blocks (FORUM_ATTACH is better!) and you configure the forums where the topics should be fetched, then only topics with SHOW IN PORTAL flagged will be shown in portal.
I've used this feature to create some advertisements forums... to allow users to insert topics in portal with some limitations... only your fantasy is the limit on how you can use this switch...
**Bump**
Yes I have an idea!
First off, sorry for "Bumping" Secondly, thanks for the response and I will check it know to see if it works. Get back to you soon...
Post Re: How To Use Show In Portal Function
No problem... let me know!
P.S.: Moved to Docs.
