Problems Using OTF To Gallery!
Subject: Problems Using OTF To Gallery!
i can upload by ftp, view it on OTF but i cant pass it to gallery... when i press ok i see that all pictures has been moved.. but nothing happen!
You can see some pictures here:
the website is h**p://***.fiebremarina.com
thanks!!!!!! :(
Subject: Re: Problems Using OTF To Gallery!
PLEASE SOMEONE HELP MEEEE!!!
Bumping your own post in such a short amount of time has earned you the Yellow Card.
Support here is free and that means we all live regular lives with other obligations and most times can't offer an immediate response.
At times, you could even expect no answer for several days.
Now I've used up all my alloted support time in this reply.... maybe I can return tomorrow. :mricy:
Did you do this step of the install ?
#-----[ DIY INSTRUCTIONS ]------------------------------------
CHMOD these directories for Full Album Pack to work correctly.
CHMOD 777 album_mod/upload
CHMOD 777 album_mod/upload/cache
CHMOD 777 album_mod/upload/med_cache
CHMOD 777 album_mod/upload/otf
CHMOD 777 album_mod/upload/wm_cache
i have a problema with navegator IE
the textbox where bbcode is
how can i fix it???
avmp,
Please create a new support topic as your problem is not related to the same problem discussed in this thread.
Chaotic thanks
i already fixed it
Generation Time: 0.1218s (PHP: 16% SQL: 84%)
