Diff Renderer
Subject: Diff Renderer
Hi all.
I have created ModX diff renderer to easily create code changes packages.
Original Discussion here: http://www.phpbb.com/community/viewtopic.php?f=71&t=804975
My instructions: http://www.phpbb.com/community/viewtopic.php?p=5162335#p5162335
Download: http://www.icyphoenix.com/_release/...dx_20080417.zip
To use it you have to:
  1. Download and unpack this ZIP into your site or your local testing environment.
  2. CHMOD to 0777 the folder where modx_file.php is, otherwise you won't be able to create the XML output file.
  3. Create two folders to be compared: one with the original files and one with the changed files.
  4. Open and edit this part of modx_file.php to correctly set the path of the previously created folders:
    1. $original_path = '../_diff/bp128/';
    2. $working_path = '../_diff/bp129/';
    3. $modx_file = 'install.xml';
  5. Open and edit modx_template_header.php adding description of your mod and your datas.
  6. Launch in your browser modx_file.php.
  7. The XML file will be created in the same folder where you have modx_file.php.
Currently it doesn't add new files to be copied... but may be easily added.
Special thanks to evil<3 for having started and created this.
Subject: Re: Diff Renderer
Igor (evil<3) it's one of the guy's that teach me what i know form phpbb
so thanks igor and, obviously, luca!
works like a charm :mrgreen:
At the risk of sounding like the stupid idiot I am... do you need subversion for this?
No, this script is standalone... you don't need SVN to run it. You have only to follow instructions. ;)
You may also be interested in this which is much more automated:
http://www.icyphoenix.com/viewtopic.php?f=32&t=4613
But this is based on phpBB 3... maybe someone will find the time to adapt to Icy Phoenix boards... and that would be great for developing and updating boards. :wink:
Generation Time: 0.0919s (PHP: 24% SQL: 76%)
