Milky Way Red - Moving Down The Top Nav Bar
Subject: Milky Way Red - Moving Down The Top Nav Bar
Can you please help me move down the top nav bar. I changed the header to 200*1185 but the nav bar is still near the top.
I have searched through all the forums trying to find the answer. This template must be different because when I look at open_header,image set or menu_block I can not find the answer.
Please, please, please
You can see for yourself at:
***.protestthemedia.com
Subject: Re: Milky Way Red - Moving Down The Top Nav Bar
you mean 1 or 2 ?
see pic
nav
@Stuff : move this please to phpBB3
Limun wrote: [View Post]
you mean 1 or 2 ?
see pic
Boy do I feel like a dork. Your picture shows it the right way. On my computer it shows that the navbar is half way through the header. I checked it on another computer and it looks the way you have it.
I guess I need to make the header a little smaller so that the page isn't so wide.
Thank you and sorry for the trouble.
Off Topic
jpiibna,
I love the idea behind your website. I'm a strong conservative myself and will not be voting for Obama.
On the subject of this topic, you are right. Shrinking your banner a little should put things in order. 8)
jpiibna can you please write down which files you edited in order to fit the resized logo?
nvm, i just realized that i had to refresh the style every time i made a change :mryellow:
Generation Time: 0.3426s (PHP: 9% SQL: 91%)
