i would like to add the prime quick login to the milky way navbar. like this (prosilver) h**p://computercentral.cc/?style=1
i can't work out your template properly, i've managed to add it in standing alone, but i would like intergrated into the navbar like with prosilver
any help will be greatly appreciated.
Prime Quick Login And Milky Way
Subject: Re: Prime Quick Login And Milky Way
if you like how is ion this pic
than
open your stylesmilky_waytemplateoverall_header.html
find
affter add
backup your overall_header.html before you do this
@Staff move this please to phpbb3 section
than
find
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --><span style="color:#CC3333;">{L_BOARD_DISABLED}</span><!-- ENDIF -->
affter add
thanks that worked perfectly =]
and sry for posting in wrong section, tried deleting after i realised but couldn't =[
edit::
umm, is there anyway i can get ajax reg checks working with it too :/ also tried this and failed LOL.
edit::
anyway to get ajax registration checks working with the style?
Generation Time: 0.0899s (PHP: 23% SQL: 77%)
