SOLVED Milky Way Edit Logo Size
Subject: Milky Way Edit Logo Size
how can i edit the size of sitelogo_small.png? i tried changing the values on imageset.cfg but with no luck.. i found a resolved thread about this one but the author didnt say on how he resolved this.. infact, no one did say anything on how to do it..
Subject: Re: Milky Way Edit Logo Size
open your stylesmilky_waytemplateoverall_header.html
find
and replace with
so here you can try chage it width="200" height="150"
if you need more than 150 of height you will need also to cgane it in
stylesmilky_waythemestylesheet.css
here
Limun wrote: [View Post]
find
and replace with
here
i tried it but it didnt work.. all it did was change the size of the banner(the orange one) behind the logo.. but i managed to change it though thank to you helping me find "<td height="150" align="left" valign="middle"><a href="{U_INDEX}">{SITE_LOGO_IMG}</a></td>"..
heres what i did:
i just replaced the "<a href="{U_INDEX}">{SITE_LOGO_IMG}</a>" with an img tag and the source of my new banner.. not sure if its a good idea though but it seemed to work... the method i used would leave some codes unused.. :P
Marking this issue as SOLVED. Feel free to continue contributing to this topic though. :)
Subject: Re: SOLVED - Milky Way Edit Logo Size
I dont think we need such a difficult procedure resize logo :mrgreen:
follow these easy steps :
1.login to ACP(admin control panel)
2.click styles and then imageset
3.there you can give dimensions for whatever you want :mryellow:
Thanks for this suggestion... but in this case I think we need also CSS editing because if the user would like to have a bigger logo, then the container is not big enough for it.
Myth wrote: [View Post]
Generation Time: 0.0841s (PHP: 22% SQL: 78%)
