PhpBB3 Forum Posting Problem
Subject: PhpBB3 Forum Posting Problem
Hello all,
I am a little new at the forum thing but I have installed phpBB3 on our server and am running the black perl style which I must say is very nice, I am trying to get familiar with all of the options and such and have made up a few test forums but for some reason I can not see any button or link in the forum to post a topic in the forum, Im not sure if I have the permissions wrong or what, if someone could help me out it would be much appreciated, thanks.
Subject: Re: PhpBB3 Forum Posting Problem
do u see buttnos on other styles subsilver2 or prosilver ?
I switched to pro silver as you suggested and still have no "new topics" button to post to forum, thanks.
Bwilly wrote: [View Post]
than i think is something in your permisions ,
did you edited affter install permisions?
Yes your right as I noticed that in the forum permissions for registered users it was set to read only and when I changed them to full access I now have the new topic button to post, but is the full access option ok to use as I see there were other options as well?
well this depend how you like that your users have permisions ...
anyway i think you have advanced permisions where you can exactly decide what registred users can or cant do ... check it...
BTW i m not so much in phpbb3 so i didnt played with permisions
Thanks for all your help it was much appreciated, I will have to figure the permissions out as it is a little confusing for me but a least you can post a topic for now, again thank you.
Which is the default language?
Are you sure to have the proper folder with all buttons in your selected language?
Generation Time: 0.0909s (PHP: 20% SQL: 80%)
