Hello friends, I use the theme Milk_Way and I want to edit the size of the image sitelogo_small to width = 942px height = 160px because I want to replace by another but I'm beginner and I don't know how to edit this, if someone can help me I would be very grateful.
forgive my bad English
[SOLVED] - Edit Size Of The Sitelogo_small
Subject: [SOLVED] - Edit Size Of The Sitelogo_small
Subject: Re: Edit Size Of The Sitelogo_small
hi crow,
you can do this in your admin panel ...styles tab>>milky way>>imageset>>edit, this way you are able to reset the size with a refresh!!
or you can make this more permanent by going to ... styles/milky way/imageset/imageset.cfg, and look at ..
# Images
img_site_logo = sitelogo_small.png*190*280
(if milky way has the same setup as black pearl ;-) )
# Images
thanks that was exactly what I needed, thank you very much. :D :D
Generation Time: 0.1665s (PHP: 11% SQL: 89%)
