Can I Get A List Of Changed Files For Black Pearl?
Subject: Can I Get A List Of Changed Files For Black Pearl?
I recently discovered Black Pearl has been upgraded for phpBB3 3.0.6 and I want to upgrade my Black Pearl theme. I've made a lot of modifications to the theme and I realize there's no easy way of upgrading my theme and keeping these modifications I've made. WinMerge is making it a little easier for me though. I had a little look around and I couldn't find a list of files which have been changed since the last version of Black Pearl. If I could get this it would save me a lot of time. Thanks.
Subject: Re: Can I Get A List Of Changed Files For Black Pearl?
List is in readme.txt
Anyway here you are:
* 2009/11/21 - Version 1.6.0
- Style updated to phpBB 3.0.6
- Files updated:
# style.cfg
# imageset.cfg
# template.cfg
# theme.cfg
# stylesheet.css
# breadcrumbs.html
# breadcrumbs_pages.html
# captcha_default.html
# captcha_qa.html
# captcha_recaptcha.html
# forumlist_body.html
# index_body.html
# login_body.html
# mcp_forum.html
# mcp_front.html
# mcp_logs.html
# mcp_notes_user.html
# mcp_post.html
# mcp_reports.html
# mcp_topic.html
# memberlist_im.html
# memberlist_view.html
# overall_header.html
# posting_body.html
# posting_buttons.html
# posting_smilies.html
# quickreply_editor.html
# report_body.html
# search_results.html
# simple_header.html
# ucp_agreement.html
# ucp_groups_manage.html
# ucp_main_drafts.html
# ucp_main_front.html
# ucp_main_subscribed.html
# ucp_pm_history.html
# ucp_pm_viewfolder.html
# ucp_pm_viewmessage.html
# ucp_profile_signature.html
# ucp_register.html
# viewtopic_body.html
# viewtopic_print.html
Oh, how silly of me...I should have checked that. Thanks a lot.
You are welcome!
that many files? :shock: :shock: i thought you said only a few files were changed :mryellow: :mryellow: :roll: :mryellow: :mryellow:
well anyway i m in the middle of updating finally, i'm having doubts about the automatic updating because i discovered some language files where not downloaded , replaced or merged .. nothing (don t understand why this happened though :oops: )
this has made me check all language files pfffewww, i m starting to regret ever changing this much to those files in both dutch and english :( (next time might be better to just do the languages manually using a list of changes to be added)
eventhough i started doubting the update to be correct, i see no way to check if all changes are actually made or downloaded, guess i ll have to wait and see
little question:
i noticed a few pictures were updated in subsilver2, i m not so worrieed about the icons because they allready exist in black... i m just wondering about that background picture, where is it used? is there no replacement for it?
It's not me wanted to edit so many files... it's phpBB Dev Team! :P
Regarding automatic update, I can't tell... because I have updated manually (it's the way I prefer!). Did you try asking @ phpbb.com?
Regarding new images, I can't remember new images added to subSilver 2, can you please tell me which ones? Anyway I think that Black Pearl doesn't need those...
i m not blaming you :LOL: it's all appreciated MG but i just thought a few was maybe 5 hahahah, just my luck
well i ve reverted and now think i m on 3.06, all looks fine sofar only blackpearl has not been updated (wich seems to cause the smiley popup not function as usual because something has changed there obviously)
about the images .. they replaced a few post icons in subsilver2 but black pearl has those allready ofcorse, the only image replaced that black pearl does not have is /styles/subsilver2/theme/images/background.gif
i dont know where it s used ..the only thing i know is that they seem to have shrunk it alittle in this update
He he he... yes, this update is something unusual for phpBB that usually stick to their release without changing that much. Honestly I prefer this new way... even if with some unwanted problems. :P
Do not mind about that background image, it is not needed by Black Pearl.
i believe i will love these changes too ...if i get them working :LOL:
next update i might look more closely at how to update manually, this could be a good idea for me too
just to be sure... there's only the full pack and the changed files list. there's no black pearl codechanges manual right?
Winmerge should be of help there
i know but it still got me in trouble :oops: thanks for the heads up though Spydie :wink:
No codechanges... I have to quote spydie... use WinMerge to compare original packages of your templates: the one you had installed and the one you would like to install. The purpose of comparing original package is that you can easily view what is changed.
You can try to use this tool to try to automatically generate changes:
http://www.icyphoenix.com/viewtopic.php?f=32&t=4134
It is easy to use, and it was coded by me when I needed to generate changes for one old version of Black Pearl! :wink:
thnx that sounds intresting allready i will read it alittle later, first i have a new problem that i will post in the other thread to keep things simple :mryellow: and then i need foooooood :oops:
gr888888
Generation Time: 0.0897s (PHP: 23% SQL: 77%)
