Q & A CAPTCA For Black Pearl
Subject: Q & A CAPTCA For Black Pearl
Hello All,Im running phpBB 3.0.7 and useing Black Pearl.
I would like to use the Q & A CATCHA...but its not showing the question,just a place for the answer.How can I fix this....Thanks for Your Time.
Subject: Re: Q & A CAPTCA For Black Pearl
hi there ror1,
can you confirm you have also updated your style to 1.6.1 (or at the very least 1.6.0) and not only the phphbb version?
Edit: if not you can find it here...
http://www.icyphoenix.com/dload.php...id=1&file_id=52
:wink:
Yes I have...
kindof obvious but you never know... did you also configure at least one question then?
Edit: in the correct language!
I have two questions,hmmm.....where would I look...I thought it would be english..How do I check and where.
CAPTCHA module settings in general tab of ACP
when you set it to do Q&A a configure button appears, if your board has different language(s) besides english i think it needs at least one question per installed choosable language
anyone please correct me if i m wrong :mryellow:
I just checked...they are set to en_us.Is this right?
what language is your board using?
only english? only another language? or multiple to choose for the user?
Only english.In the imagest I changed the folder name for en to en_us....could this be my problem.
well to avoid alot of confusion, if the user not seeying the question has his settings also on en-us i think it's not likely to be the cause (EDIT: i also don t think captcha q&a uses any images)
i wonder in this drop down menu for the Q&A language is en-us the only choice there, i mean if there's no other choice .. we are likely to be searching in the wrong direction
LOL don t be sad... if i can t help i m sure someone else can ..
i asume you are the user that does not see the questions...
is your profile set to use en-us? are the board preferences set to the same ?
is there a choice in the q&a dropdown language menu or is it only en-us?
Board preferences set to the same.Im the admin.If I log off and then hit register(when I have Q & A ) All I see is the answer box.Its only english. There is no q&a dropdown language menu,only en-us.
This is what I see in the ACP:
{ AVAILABLE_CAPTCHAS }
{ CAPTCHA_SELECT }:
{ CAPTCHA_SELECT_EXPLAIN }Q&A CAPTCHAGD CAPTCHAreCaptcha{ CAPTCHA_CONFIGURE }:
{ CAPTCHA_CONFIGURE_EXPLAIN }
Preview
are you good looking : <-----( answer box is here)
This question is a means of identifying and preventing automated submissions.
{ ACP_SUBMIT_CHANGES }
This is whats in the templates
captcha_qa.html
<tr><th colspan="2" valign="middle">{L_CONFIRM_QUESTION}</th></tr>
<td class="row1"><b class="genmed">{L_CONFIRM_QUESTION}:</b><br /></td>
<td class="row2"><input class="post" type="text" name="qa_answer" size="80" /></td>
<input type="hidden" name="qa_confirm_id" id="confirm_id" value="{QA_CONFIRM_ID}" /></td>
well looking at that i see a whole lot wrong
first of all you should not see any {AVAILABLE_CAPTCHAS} etc. on your site .. not even in your admin panel, this means it's missing the language replacements for those
but most of all my captcha_qa.html looks like this:
<tr><th colspan="2" valign="middle">{QA_CONFIRM_QUESTION}</th></tr>
<td class="row1"><b class="genmed">{QA_CONFIRM_QUESTION}:</b><br /></td>
i can only say you must have done something wrong during updates?
:( So can I fix it by changing it to what you have?
Is the captcha_default.html right?
<tr><th colspan="2" valign="middle">{L_CONFIRM_CODE}</th></tr>
<tr><td class="row3" colspan="2"><span class="gensmall">{L_CONFIRM_EXPLAIN}</span></td></tr>
<td class="row1" colspan="2" align="center"><img src="{CONFIRM_IMAGE_LINK}" alt="{L_CONFIRM_CODE}" />
<input type="hidden" name="confirm_id" id="confirm_id" value="{CONFIRM_ID}" /></td>
<td class="row1"><b class="genmed">{L_CONFIRM_CODE}:</b><br /><span class="gensmall">{L_CONFIRM_CODE_EXPLAIN}</span></td>
<td class="row2"><input class="post" type="text" name="confirm_code" size="8" maxlength="8" /><!-- IF S_CONFIRM_REFRESH --><input type="submit" name="refresh_vc" id="refresh_vc" class="btnlite" value="{L_VC_REFRESH}" /><!-- ENDIF --></td>
Generation Time: 0.6965s (PHP: 4% SQL: 96%)
