[Help]Milky Way portal install
Subject: [Help]Milky Way portal install
im having trouble finding some text in milky way style..
how to solve this?
overall_header.html
Find:<div id="menubar">
Add before:<!-- IF not $S_IN_PORTAL -->
Find:<!-- INCLUDE breadcrumbs.html --><br />
Add After: <!-- ENDIF -->
breadcrumbs.html
Find: <p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a>
Replace With: <p class="breadcrumbs"><a href="{U_PORTAL}">{L_PORTAL}</a> » <a href="{U_INDEX}">{L_INDEX}</a>
overall_footer.html
Find: <!-- IF TRANSLATION_INFO --><br />{TRANSLATION_INFO}<!-- ENDIF -->
Add After: <!-- IF S_PORTAL_COPY --><br />{S_PORTAL_COPY}<!-- ENDIF -->
Subject: Re: [Help]Milky Way Portal Install
I ve moved this post out of the release thread to phpBB 3 MODS And Styles, please use the release thread for bug reports and "thanks MG" messages
because this is a double post i also want to ask you to not post the same question twice, i will reply in the other thread ( wich i splitted for you BTW )
Generation Time: 0.1797s (PHP: 9% SQL: 91%)
